when you say z bar, you are talking about the clutch pedal linkage to the trans correct. does this differ from models and makes. And will there be a differance on which trans you use?? thanks for the insight
The z-bar goes from the frame rail to the motor,or bell housing. The linkage rods can be different per the application
