Just looking for some help on this subject. I have mustang disc brakes for the front and 87 mark vii rear discs for the rear. I just bought a maverick power brake setup, with the booster, and proportioning valve. Next i need to install everything, and run new lines. Any help on this subject would be appreciated, also if i could get pictures of how the power brake setup mounts along with the prop. valve. that would be much appreciated, Thanks.
I had forgotten about that thread, thank you. Do you know will the proportioning valve work with rear disc brakes?
