Adjustable strut rods
Discussion in 'Technical' started by Broncobru, Dec 19, 2015.
  1. Broncobru
    Broncobru Member
    Dunnellon Florida
    1972 Ford Maverick
    What is the advantage of using a after market adjustable strut rod? Who makes a good set?
    Thanks, Joe
  2. dyent
    dyent Member
    vancouver bc
  3. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    The stock strut rods are adjustable.
  4. Broncobru
    Broncobru Member
    Dunnellon Florida
    1972 Ford Maverick
  5. Broncobru
    Broncobru Member
    Dunnellon Florida
    1972 Ford Maverick
    I know. I saw a ad for aftermarket struts rods and was wondering if there was some advantage in using them.
    Thanks, Joe
  6. Dave B
    mojo likes this.
  7. mojo
  8. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    $400 is a bit pricey for a set of strut rods. I'd rather put that money toward a complete coil-over front suspension.
    The stock rods with new bushings are plenty adequate for normal driving. If you're going racing, you're going to want a better suspension system anyway rather than trying to make the old set-up perform to 21st century standards.
  9. Dave B
    Most complete coil over suspension, come with adjustable strut rods. Reinforced upper and,lower control arms, roller perches, good shocks and spring, and adjustable strut rods, are more than enough for most people. Tubular control arms just add weight to the car.
  10. dyent
    dyent Member
    vancouver bc
    A set can be purchased from: Tracy Blackford
    PTP Engineering Inc.
    ptpengineering@yahoo.com
    for $249
    Crazy Larry likes this.
  11. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    That's definitely a better deal.
  12. Broncobru
    Broncobru Member
    Dunnellon Florida
    1972 Ford Maverick
  13. Broncobru
    Broncobru Member
    Dunnellon Florida
    1972 Ford Maverick
  14. dyent
    dyent Member
    vancouver bc
    LCA...........lower control arm
    joe stanley likes this.
  15. dyent
    dyent Member
    vancouver bc
    I believe Ed (rotorr22) installed a set, you can contact him through forum's conversation.......
    David
