Another 4 lug to 5 lug
Discussion in 'Technical' started by alexzoinks, May 2, 2005.
  1. alexzoinks
    alexzoinks New Member
    Portland, OR
    72 Two door 200 c4. 74 Four door 250
    I have done a search in the archives but I still can't find an answer. I will soon be doing a 4 lug to 5 lug conversion. Parts are coming off a 74 four door and going on the 72. I know the rear end will bolt right in, but I was wondering about the front. Does anyone know if there is any difference there. It is drum all around. Might there be a difference in tie rods or ball joints? I think it would be all the same.:16suspect Any help would be appreciated.
  2. Kilg0re
    Kilg0re Doh!
    Lees Summit, Missouri
    I have a 70 and I'm not sure what year the disc came from but it bolted right on with no problem. I want to say it was later year. If you would like some pics I can take some just let me know.
  3. 71gold
    you didn't mention if it was power or not. my swap was non power. i took the parts off a '75 mav. i just dropped the whole front end....dropped my drum set up and bolted the disc set up on...took my son and i about two (2) hrs...frank...
  4. Kilg0re
    Kilg0re Doh!
    mine was on non power too
  5. Earl Branham
    Lugoff, SC
    I have non-power disc brakes on a 69.5, came from a '74 Comet. Fit very well, no problems and no surprizes.
  6. Kilg0re
    Kilg0re Doh!
    Just wondering if you started the change yet and how everything is going with it...
