Auto trans vacumn modulator
Discussion in 'New Members Forum' started by old preacher, Jul 4, 2014.
  1. old preacher
    old preacher Member
    Colorado
    1973 Ford Maverick
    I am new to this forum. haven't logged on since last fall. But during the winter I got my 73 maverick running. But the vacumn modulator on the tranny is bad. It has two vaccum lines. a guy at a transmission place said to replace it with one with a single line? Can anyone help me? When I went to the parts store they had a green strip, a yellow strip and a red stripe. What does all that mean?
    Thanks Old Preacher
  2. doncomfort
    chillicothe oh
    You want the green stripe.
  3. old preacher
    old preacher Member
    Colorado
    1973 Ford Maverick
    Thanks, I got a green strip one yesterday at the parts store. Now I am having a problem with the vaccum line. The old one had the two vaccum hook ups that pointed out and away from the modulator. The new one has a place to attach the lines in the back but the modulator is right up against the cross member that holds the transmission up. I guess I have to remove the cross member and try to attach the hose some way and then get the cross member back on.
    Old preacher
  4. MaverickDan
    Midlothian, VA.
    73 Maverick 4dr
    You should be able to replace the modulator and attach the vacuum line without removing the cross member. Also your gonna need a new modulator hold down the dual line hold down is different.
  5. simple man
    simple man Member
    Bunnell,Florida
    I used ¼" fuel line to hook mine up. It is flexible, but won't kink making the bend around the crossmember. I used a pair of long needle nose pliers to put the hose on the modulator. Also, use only the larger of the two metal lines. You can either remove the smaller one, or just leave it there. :)
  6. 71gold
    is there room for a...molded 90 degree hose...you can find them on a lot of late model stuff...:yup:
  7. old preacher
    old preacher Member
    Colorado
    1973 Ford Maverick
    I could not make the Green Strip work so I put a new modulator with the two connections on it. The transmission still will not shift automatically. It shifts fine if I manually go through the gears with the shift lever. Any suggestions?
    Thanks
    Old Preacher
  8. GreyGhost74
    GreyGhost74 Member
    FL
    1974 Mercury Comet
    If the modulator works and none of the hoses are kinked I'd check the vacuum coming off the motor and make sure its where it should be.
