Baer Front Disc Brake Conversion
Discussion in 'Technical' started by Maverick Dude, Sep 21, 2022.
  1. Maverick Dude
    Maverick Dude Member
    Cranbrook, BC Canada
    I’m looking at a straight conversion of the front brakes from drums to discs using the stock drum spindle. Baer has a conversion like that, but I was wondering if anyone has direct experience with it. I’m trying to minimize the investment but was wondering if the brake feel and stopping distance is improved. This is not a power brake conversion. Here are some screen shots.
    57905AFD-9454-46E5-A06C-D8BCCB2637D8.jpeg 1330B016-7A83-4A0D-8AF2-37DEE0F90502.jpeg
  2. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    Should be leaps and bounds better than drums. One thing to be aware of, master cylinder bore diameter and pedal ratio have a lot to do with pedal effort so you might want to contact them for recommendations on which one would work best. Whatever you do, get the right one, drum brake masters are different than disc, a lot of people run them without issue but they may get better performance with a different one.
    ike72com and Maverick Dude like this.
  3. mojo
    If my car didn't have Granada conversion; I would have this setup. Granada conversion does a goood job, but, I believe this would be a big improvement over the 2 piston system.
  4. bmcdaniel
    bmcdaniel Senile Member
    Yep, even the later Maverick disc setup is much better than drums, this has to be better yet. Maybe consider using an '89 Ranger disc/drum master cylinder, if you don't mind the look of a more modern piece. I like it because I can check the fluid level without opening the top.
    71gold likes this.
  5. Falcenac
    Falcenac Member
    Sechelt B.C. Canada
    1969.5 Maverick 71 Comet G.T. 76 Comet 4 door 61 Falcon x2 60 Frontenac
    Is that Ranger master for manual brakes and is it a direct bolt in or any mods needed?
  6. bmcdaniel
    It works fine with my manual brakes but I think it was originally for a power setup since the pushrod isn't captured in the piston and could fall out. Added a small L bracket under the dash to keep the brake pedal from coming back too far. Picked up a pair of adaptor fittings at Advance Auto to mate the original brake lines to the MC. I did use an adjustable pushrod to get the pedal height just right.
    https://www.performanceonline.com/Ford-Mercury-Manual-Master-Cylinder-Push-Rod-Kit/
    71gold likes this.
  7. Falcenac
    Falcenac Member
    Sechelt B.C. Canada
    Thanks for the info!
  8. canuck222
    canuck222 vroom, vroom... Supporting Member
    Woodstock, ON
    '73 Mercury Comet, 302, Auto
    Is there any advantage of going with Baer vs. Wilwood? Quality, completeness of kit, parts availability etc?
