champion aluminum radiators
Discussion in 'General Maverick/Comet' started by satchelmcqueen, Aug 3, 2017.
  1. satchelmcqueen
    satchelmcqueen Member
    rome georgia
    was looking at jeggs website and for around $280 i can get a 3 row to help cool the 347 im going to get very soon. is there any reason to get a 4 row instead? its only about $40 more. i may get it if i can make one fit. thoughts??
  2. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    The more rows it has, the more air you need to move through it, or else it will actually run hotter than a 2-row. The 2-row Champion actually cools as efficiently as the stock 3-row with the stock fan. I see no reason you would need a 4-row with a 347.
  3. satchelmcqueen
    rome georgia
    thanks and this is also what ive read since posting this.
  4. 73curtis
    73curtis Member
    ohio
    griffin radiators and c&r radiators are very nice also
  5. 55crownvic
    55crownvic Member
    colorado springs
    I have had several champion 2 rows and they work perfect, i believe the # is 339
    satchelmcqueen likes this.
  6. Craig Selvey
    I have a factory stock radiator on my 347. No issues.
    73curtis and satchelmcqueen like this.
  7. randymcfp
    randymcfp Member
    Conyers, GA
    2012 Taurus, 2004 Escape
    We are a Champion Cooler distributor. If we can help in any way, please let us know!
  8. stumanchu
    stumanchu Stuart
    Portland, OR
    If you are going to use a Taurus fan, the fit with a three row gets very tight. I had to get a two belt bottom pulley to make it work, but I dont have AC. I dont know anything about 5.0/serpentine set up.
  9. 55crownvic
    55crownvic Member
    colorado springs
    dont really need a three row...a two row works fine.
    71gold likes this.
  10. mrmalina99
    mrmalina99 Member
    Warner Robins, GA
    1973 Maverick
    I have a 3 row with the Volvo fan, works great but clearance is really tight.
  11. William623
    Orlando
    1973 ford maverick grabber
    Three row works perfectly, honestly a 2 row would be fine. Also using the Volvo fan. Required a custom shroud but it was cheap and powerful.
    mrmalina99 likes this.
