fuel line route around headers?
Discussion in 'Technical' started by newtoford, Aug 12, 2008.
  1. newtoford
    newtoford Member
    New Castle Delaware
    so some of you guys with 302's and headers may have noticed that the stock steel line that exits out of the frame right under the master cylinder points almost directly at the header. im thiniking the best and safeist place to run that line from there is down next to the oil pan under the motor mount but obviously high enough where suspension isnt going to get in the way or yank it loose, and then just plug it into the mechanical fuel pump which isnt far from there. the onlu other thing i can think is to take the rubber line up along the top of the shock tower and back down again to get to the fuel pump but i dont want to run into any fuel delivery problems with having such a high point in the fuel system. the tank and all the lines before the pump are lower then the pump and i think its like that for a reason
    but anyway, i look foward to hearing some opinions.
    thanks
  2. just1993
    just1993 Mike
    Zionsville, PA
    70' & 71' 2 Door and 76 4 Door
    On a 302 car the fuel line enters the engine bay in front of the shock tower. All you need to do is make up or buy steel tubing from the rubber juction under the driver seat. Run the extension through a new hole in front of the shock tower (through a grommet of course). Straight to the fuel pump on the engine with a rubber line.
  3. newtoford
    newtoford Member
    New Castle Delaware
    ohhh i see that makes sence
    im doing the I6-v8 swap if it wasnt already evident lol
  4. Andysutt
    Andysutt '72 Comet GT
    Conway Arkansas
    1972 Comet GT
    Yup, fuel line comes out in front of the shock tower, great place for it :)
  5. newtoford
    newtoford Member
    New Castle Delaware
    i guess i never took a close enough look at my frame to notice anything like that
