Headliner
Discussion in 'Technical' started by MarulMav, Mar 16, 2006.
  1. MarulMav
    MarulMav Member
    Bellevue, Nebraska
    1975 Maverick (Grabber Clone)
    Can anyone tell me the basics of installing a headliner? Do the windshields have to be removed? Is it better to pay for it to have it installed? I have the material on hand, but have no idea on how to attempt it, or even if I should. Thanks.
  2. sierra grabber
    sierra grabber Certifiable
    northern nevada
    you will have to pull the windshields to do it.
  3. grbmaverickmo
    Aquashicola, PA
    Have a pro do it :2cents:
  4. Jamie Miles
    I think it would be well worth it to pay someone that knows what they are doing.
  5. ATOMonkey
    ATOMonkey Adam
    Plainfield, Indiana
    '69 & 1/2 Maverick
    Really?? Windshields out? Wow! I didn't think it would be that involved. I guess I'm used to working on other cars. Refinishing the headliner is easy as long as you can get it in and out. Just pull off the old material, sand off the glue and left over fabric. Spray the board and fabric with glue. Then start at one edge and slowly roll the fabric onto the board like you would a sticker or decal. Just don't let it wrinkle whatever you do! A neat trick is to put foam between the board and fabric in different designs. Gives you a 3D custom headliner.
    This website shows what I'm talking about. http://www.all-nu.com/html/customflames.htm
    If I'm wrong about how the maverick headliner is put together, just tell me I'm and idiot and ignore the above post.
  6. Tom Laskowski
    Tom Laskowski Member
    Bay Area,California
    (3) 71's,two V-8's and one 200 cid
    There is no board on the Maverick to glue anything to, it's held in place by the front and rear windshield gaskets the overhead bow's, and the side windlace. Best bet is to order new gaskets and have them in hand before you even think about doing this job, I had one put in a while back and the labor was $262.00, not counting the glassman. Not cheap!
  7. ATOMonkey
    ATOMonkey Adam
    Plainfield, Indiana
    '69 & 1/2 Maverick
    Wow!!!
    I wonder if there's a way to redesign that so it doesn't involve glass removal.
  8. MaverickGrabber
    Cardington, ohio
    1972 Maverick Grabber 393w
    yeah and it looks good too(y) :biglaugh:
  9. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    Glass has to be out,, have a pro take out the glass and try it yourself, take your time, with some spray glue and patience you can do it. Keep the rods in order,, install and order some new front and rear glass seals, have your glass man reinstall when you getter done. Only one way to learn,, do it!
    Dan
  10. Dave B
    One of my niegbours is retired for the Ford plant in St. Thomas, he use to do them when they were being built, he's going to help me with mine when it goes back in. He did say to make sure the bows don't get mixed up because they are different.
  11. mavman
    mavman Member
    Arkansas
    Apparently there was only ONE person in the world that didn't have to remove the glass to install it. When I had my '74 street car, we took it to Harper's upholstery here in central Arkansas. He charged us I think $75 to install the liner (we bought the liner from AutoKrafters, IIRC) and it was AWESOME...and he didn't have to remove any glass.
    Keep in mind that Mr. Harper passed away a year or so ago and his business is also gone. His work will always be remembered--he did some work for the original Batmobile way back when.
    We asked him how he put it in without removing the glass. His reply was something to the affect of it being a trade secret. I guess it's like asking a fisherman where his honey-hole is.
  12. jhossrock
    jhossrock Member
    scranton,pa.
    1972 4dr. maverick
    you don't have to take the windows out. when you remove the old one label the rods.use the old liner for a guide. when putting the new one in just use a hair dryer to soften the liner, then with a putty knife or other well rounded smooth thin tool, heat up the area and slide the liner in. work from the center out. take your time you can do it.
  13. hotrod-daddy
    hotrod-daddy Member
    Rock Springs,Wyoming
    a 1971 Grabber with a 302/351
    How many bows are there in the 2 door Maverick?
  14. sierra grabber
    northern nevada
    Tom,
    Where did you get yours done? is the place in san leandro? thinking about who is going to do mine.
  15. Mavaholic
    Mavaholic Growing older but not up! Supporting Member
    There are four
