Installed 3G alt and now gas gauge is having issues
Discussion in 'General Maverick/Comet' started by mrmalina99, Aug 26, 2015.
  1. mrmalina99
    mrmalina99 Member
    Warner Robins, GA
    1973 Maverick
    How would you adjust it? Is there a screw? Also RadioShack does not exist anymore.
  2. mav man
    mav man Member
    wi
    70mav
    Radio shack is still around.
  3. mrmalina99
    mrmalina99 Member
    Warner Robins, GA
    1973 Maverick
  4. gregmaverick
    gregmaverick Member
    Salem, OR
    1970 maverick
  5. mav man
    mav man Member
    wi
    70mav
    We still have 2 radio shacks here in central wi
  6. mrmalina99
    mrmalina99 Member
    Warner Robins, GA
    1973 Maverick
    Looks like there are some stores about an hour away.
  7. mrmalina99
    mrmalina99 Member
    Warner Robins, GA
    1973 Maverick
  8. mrmalina99
    mrmalina99 Member
    Warner Robins, GA
    1973 Maverick
    Got the Radioshack rheostat today. Anyone got instructions or info on this process?
  9. gregmaverick
    gregmaverick Member
    Salem, OR
    1970 maverick
    See Schematic.
    On the Radio Shack variable resistor, connect the center post to one of the outside posts.
    Connect your "fixed value" resistor to one of the outside posts.
    Wire this assembly in "series" with the sending unit wire. (Either near the tank, or at/near your gauge).
    Adjust variable resistor to reflect the amount of fuel in your tank. Hopefully, the fixed value resistor will be "in the ballpark". As other members have pointed out, you may or may not have to add or take away from the fixed value.
    Ideally (perfect world), the variable resistor will be at mid-point when perfectly adjusted. But, once you've got the gauge set where you want it, you could remove from the circuit, measure the total resistance, and then replace with a fixed value resistor with the measured resistance. :tiphat:
    Krazy Comet likes this.
  10. gregmaverick
    gregmaverick Member
    Salem, OR
    1970 maverick
    Opps...On the schematic, the Fixed Value Resistor should read 20 - 40 ohms. :slap:
