Instrument Cluster Voltage Regulator
Discussion in 'General Maverick/Comet' started by Jony, Oct 17, 2016.
  1. 71gold
    do you have A/C?
  2. Jony
    Jony Banned
    1972 Ford Maverick Grabber 5.0L 302 v8 NA
    I don't have A/C.
  3. bmcdaniel
    bmcdaniel Senile Member
    Just clean all of the bare copper contacts with a pencil eraser. Bulb sockets too.
    As mentioned, all the regulator does is supply a constant 5V or so to the fuel gauge.
  4. William623
    Orlando
    1973 ford maverick grabber
    Is that a burn on the bottom left? I have seen them before where they get too hot melt the plastic and do not work correctly.
  5. Jony
    Jony Banned
    I would clean the copper with an eraser but I've already used a circuit board cleaner i had and almost worked until it tore part of the circuit board. Yes that is a burn in the bottom left and there are also a few other burn spots on the contacts!
  6. 71gold
    I was thinking the noise you hear was a vac. pod air release on a vent door, they make a hissing sound.
  7. William623
    Orlando
    Next question is if you don't have dash lights, have you checked the fuse?
  8. Rasit
    Rasit Member
    SE Pennsylvania
    Take a multi-meter and check for continuity at each snail trail from connector to each contact along the trail. Pull the bulbs and check them too. Any breaks in continuity need to be cleaned/repaired. You can also bench test with 12volt across each bulb. Do not apply 12volt to the gas gauge as I believe the regulator output is more like 5volts.
  9. Jony
    Jony Banned
    The fuses are fine because the turn signals, alt, break and other lights come on, everything but the lights that allow me to see the fuel gauge and speedometer. I will try checking for continuity and such later but right now I have a lot going on that I really need to take care of but until I get it done I ask of others to help me figure out how to solve this with other ideas! Thanks!
  10. 71Mavrk
    71Mavrk Member
    Nevada
    I noticed you installed LED lights. Some of these are polarity specific. Unlike bulbs, + has to be + and - has to be -.
    Micah
    modmav, Paul Masson and rthomas771 like this.
  11. Shawmav
    Shawmav Member
    Louisville
    1975 Maverick
    Thanks for posting! This was my problem with my new LEDs.
    71Mavrk likes this.
