Try http://www.mustangsandmore.com/ . They could probably help you out quickly (if you haven't received an answer from this board - which you just might - there's a lot good sources here). BTW, Charlie Ping (on this board) is a moderator there. Good luck, Rick
just for thought, granada discs will work on cumstangs, granada discs work on mavs....hmmmm, so the kits for the stangs might work for mavs aswell
I know a few people in the Northern California Shelby Club that use Maverick/Granada discs on their roadrace Mustangs(65-66). I am not sure if they will work on other years, since I am not as familliar with them. This one guy had a set of $250 pads for the Maverick brakes he runs. Apparently they work really well. -Corbin
Thanks for the help guys. Rick, That website had links to some great tech. articles on the job I'm about to do. I appriciate your help. If anyone is converting a drum mav to disc, I really recommend reading the articles in the above mentioned web site on converting an early mustang to discs. You will find alot of the info very helpful. Dan
I've got a disc brake setup from a 76 mav in my 66 mustang The mav was a 5 lug, 6 cyl 1976 The mustang had 4 wheel 5 lug drums all around. the 1976 mav set up is essentially the same as the granada set up. email if I an offer any more help. Fred Fermin fqfermin@yahoo.com
