Mustang GT rims/tires/spacers questions
Discussion in 'General Maverick/Comet' started by mattwagner, Aug 12, 2014.
  1. mattwagner
    mattwagner Member
    Minnesota
    1976 Ford Maverick
    I bought some 05 Mustang GT rims on Sunday. They are 17x8 with 235/55/17 tires on them. The tires are shot and I'll have to replace them at some point. Should I go with the same size tire or go with a different size? My next question is for spacers, what size should I get? 1.5" 1.75" or 2"??
  2. 55crownvic
    55crownvic Member
    colorado springs
    I will be running 1 1/2" spacers on mine, and the front could be 1/4" larger to clear the upper ball joint.
    z28th1s likes this.
  3. 55crownvic
    55crownvic Member
    colorado springs
    forgot to mention, the pics above are my last mav, but my new one will have the same wheels, but with the silver center, and I will probably run the stock mustang tire size.
  4. mattwagner
    mattwagner Member
    Minnesota
    1976 Ford Maverick
    So should I go with 1.5" or just 2"?
  5. z28th1s
    Lynchburg, VA
    That car sure does look nice!!
  6. chandler
    chandler Member
    Warrenton Mo
    Maverick
    If you are looking for some spacers I have a set of 2" and a set of 1 1/2 billet spacers
  7. mattwagner
    mattwagner Member
    Minnesota
    1976 Ford Maverick
    A set as in 2 or 4? And how much??/
  8. chandler
    chandler Member
    Warrenton Mo
    Maverick
    PM'd you
  9. mattwagner
    mattwagner Member
    Minnesota
    1976 Ford Maverick
  10. 55crownvic
    55crownvic Member
    colorado springs
    I'd go with 1.75" spacers, that way you will have the clearance needed.
  11. h2o
    h2o Mad Mav Man
    mexico city
    1973 ford maverick gt 289 v8
    Hello,
    May I ask the exact sizes for the spacer you used for this Maverick? I’m planning on using mustang wheels on mine. Thank you
  12. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    The post right before yours (see below) he gave his recommendation. Looks like 1.75 is the magic number.
  13. h2o
    h2o Mad Mav Man
    mexico city
    Yeah I saw that, but I think this was a response to the OP’s original question, not the actual measure of the sapcers on his blue Maverick :huh:
    RMiller likes this.
  14. RMiller
    Kennewick, WA
    Reading into what he said, I would bet he ran the 1 1/2 and was recommending the 1 3/4 for some additional clearance. It's all a guessing game at this point, he sold his Maverick and hasn't been on since. I know on mine a 1" spacer works but the tie rod is close enough to the wheel it hits the wheel weights. I have 18 x 9 on the front but I also have drop spindles. Once it's time to go back together I will get either 1 1/4 or 1 1/2 spacers.
  15. h2o
    h2o Mad Mav Man
    mexico city
    yeah you’re probably right, 1.5 on the back 1.75 on the front it is. Iwonder what wheel size did he use?
