Need transmission which should I get?
Discussion in 'Technical' started by 2791fordmaveric, May 26, 2014.
  1. 2791fordmaveric
    2791fordmaveric Member
    Butler Pennsylvania
    1972 Ford Maverick
    My C-4 is starting to slip pretty bad and I am switching the motor out soon and would like to do it all at once. I would like something with an overdrive and a few more gears any suggestions on what transmission I should use?
  2. MaverickDan
    Midlothian, VA.
    73 Maverick 4dr
    An aod or 4r70w if you want to stay auto, or a wc t5 if you want a manual. You will need an aftermarket controller if you decide on a 4r70w, unless you get a full manual valve body.
  3. 71gold
    AOD...:thumbs2:
  4. 2791fordmaveric
    Butler Pennsylvania
    1972 Ford Maverick
    Will I need anything special wiring wise for the aod?
  5. 71gold
    nope...that's the AODE.
  6. 2791fordmaveric
    Butler Pennsylvania
    1972 Ford Maverick
    What cars would that transmission come in?
  7. 71gold
    1980–1986 Ford LTD
    1980–1993 Ford Thunderbird
    1980–1993 Mercury Cougar
    1984–1993 Ford Mustang
    1980–1986 Mercury Marquis
    1983–1993 Ford Econoline
    1983–1991 Ford LTD Crown Victoria
    1983–1992 Mercury Grand Marquis
    1982–1993 Ford Bronco
    1981–1992 Lincoln Town Car
    1980–1987 Lincoln Continental
    1980–1983 Lincoln Continental Mark VI
    1984–1992 Lincoln Mark VII
    1992 Ford Crown Victoria
    1980–1988 Ford F-Serie
  8. 2791fordmaveric
    Butler Pennsylvania
    1972 Ford Maverick
  9. 2791fordmaveric
    Butler Pennsylvania
    1972 Ford Maverick
    Will the bell housing from my 250 inline six still work with a 302 and the aod?
  10. MaverickDan
    Midlothian, VA.
    73 Maverick 4dr
    On the AOD the bell housing is part of the trans case. The 250 uses the same bell pattern as a sbf but has a different imbalance, so if you want to use the AOD with the 250 you'll need a 0 balance 164t flex plate which I'm not sure if one was ever made, maybe one from a 300 i6?
  11. 2791fordmaveric
    Butler Pennsylvania
    1972 Ford Maverick
    What about a 302?
  12. MaverickDan
    Midlothian, VA.
    73 Maverick 4dr
    A 302 is a small block ford so it uses the same bell as a 250, but you also have to make sure which flex plate you get depending on what year 302 you get. Early 302's(68-81) use 28oz imbalance, and late 302/5.0'(82-01) use 50oz imbalance.
  13. Bryant
    a zero imbalance flex plate is easy. take any weight flex plate and remove the weights. guess what, you have a zero imbalance flex plate.
  14. Krazy Comet
    Krazy Comet Tom Supporting Member
    Your orig C4 bell is useless with a AOD, those have a non removable bell that uses 164 tooth flexplate, the 4.6 does use a zero balance flexplate... The 1991 4.6(Lincoln Town Car) & half year 1992(Crown Vic & Grand Marquis) will have correct balance but I dunno if a 4.6 flexplate will bolt to a 250 crank... If you're going to 302, 164 tooth, 50 oz flexplates are easy as all AOD/5.0 from '81 up used those...
  15. 71gold
    late 5.0 roller motor....50 oz. flexplate and AOD.
    you can get a flex plate for an early 302 that will work with an AOD, I had one on mine...
