Question for guys with MII and no shock towers
Discussion in 'General Maverick/Comet' started by BigDog41364, Feb 12, 2015.
  1. BigDog41364
    BigDog41364 Member
    Kalamazoo Michigan
    1975 maverick
    I want to get some different headers (have Hooker 6901's now) something with a little more room to get the bolts in the head. any suggestions?
  2. Rick
    Rick G8I operations
    Laurel, Maryland
    I'm using these they fit nice with 2" tubes 3.5" collectors. note that this set has the diagonal bolt pattern designed to work with Trick Flow High Port Cylinder Heads.
    "Hooker 6231HKR Super Comp. Engine Swap Headers"
    • Super Comp. Engine Swap Header
    • Black Finish
    • 79-93 Mustang/79-86 Capri
    • Ford Eng 351W TFSR
    • Tube Sz 2 x 30 in. OD
    • Coll Sz 3.5 in. OD
    • Coll Lgth 10 in.
    • Rnd Port
  3. scooper77515
    Cliffs Notes version of my LONG story, I ended up with an oversize 7 qt oil pan, and my 6901s would not clear. I went with Hedman Shorties and actually picked up so low-end torque.
    Lots of extra room in there now!
  4. 71gold
    I used a set with the diagonal bolt pattern design on my 347 with AFR 165 heads. they make an adapter plate for them.
    Static likes this.
  5. BigDog41364
    BigDog41364 Member
    Kalamazoo Michigan
    1975 maverick
    Where did you get the adapter plate? i like the look and that the bolts are easy'er to get to.
  6. scooper77515
    No problem reaching my bolts...
  7. 71gold
  8. Wrighttime
    Wrighttime Member
    Midlothian, Va.
    74 Maverick street car 73 comet drag car 74 comet drag car
    I know you went with the R/C kit. Did you remove fender well supports? If so why?
  9. scooper77515
    Not sure what "fender well supports" are.
    I removed everything that the R/C kit instructions told me to.
  10. Wrighttime
    Wrighttime Member
    Midlothian, Va.
    Ok I see in your picture that you have not installed your shock tower patch panel.
  11. Mel Moeller
    Mel Moeller Maverick Moe
    Twin Falls Idaho
    1971 Ford Maverick, Two 1973 Mavericks, 1974 Mercury Comet
  12. 71gold
    that or have the heads drilled for the studs...:huh:
  13. scooper77515
    I have the panels, just haven't gotten around to installing them yet.
  14. BigDog41364
    BigDog41364 Member
    Kalamazoo Michigan
    1975 maverick
    RC-107 kit showed up yesterday :dancingpa: was hoping to start on it Saturday but the actual temp this morning is -19, Dont think the wood stove in the pole barn will help much.
  15. RASelkirk
    RASelkirk Retired!
    Port Neches, TX
    Dang! And I quit working when the temp gets below 45° unless it's pressing business...
