Rear end identification
Discussion in 'Technical' started by Warp9, Sep 6, 2019.
  1. Warp9
    Warp9 Member
    Simcoe Ontario Canada
    1972 Ford Maverick Grabber
    Can anyone help decide this diff tag.....?
    Thanks
  2. Krazy Comet
    2.79 ratio 8", what was in most Mav Comet. A/C cars usually got 3.00..
  3. Warp9
    Warp9 Member
    Thanks, now the hard one.....I want to put a shift kit in my c4. Are they all the same or specific to the trany. I tried to identify the trany but I'm not sure. It has a case fill tube and screw in modulator, the vent is on top so I know it's not pre 66. Ideas?
  4. Krazy Comet
    AFAIK shift kits are usually for pre 69½ & '70 later.
    If it hasn't been rebuilt, there should be a tag on on bolt for tail housing that ID model. That said, if it hasn't been rebuilt it probably should be.
  5. cyclonewill
    cyclonewill Member
    SandSprings, Oklahoma
    There are several different shift kits. Get a 70 up c4/c5. Don't be afraid to tear into it, they're pretty straight forward transmissions.
  6. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    I seem to remember when I put in a Transgo kit the instructions had details for 2 or 3 different C4 valve bodies, and how to identify each one. The kit had parts that were unnecessary for the model I had. When it shifts at WOT, it is like a mule kick in the a$$.
  7. baddad457
    Don't rebuild it, put a Toploader in it:stirthepot::cheers:
    Shorty likes this.
