My 1971 Maverick
Average User Rating:
5/5,
Ownership Satus:
Currently own it
Year:
1971
Engine:
Other 8 cylinder
Color:
Matrix Viper Red
  1. 71Mavrk
    71Mavrk Member
    Nevada
    71Mavrk submitted a new car to the Garage :
    My 1971 Maverick
  2. Paul Masson
    1971 Grabber
    WOW Micah!!! This is AWESOME!! One of the nicest Maverick builds I've seen. Glad to see it finished! Congratulations!
  3. mojo
    Very nice restoration! I like it! What issues involved installing AOD? Where are the AC vents? What type exhaust setup?
  4. mav1970
    Absolutely amazing job :thumbs2:
  5. 71Mavrk
    71Mavrk Member
    Nevada
    Paul, Thank you. I have enjoyed watching your build. I'm sure it will be equally amazing.
    Thanks Bob
    Thanks Everett.
    1. The AOD is not a difficult conversion with an EFI and a floor shift. You need the correct mount, a little wiring, some adjustments to the shifter linkage and a Lokar cable to the throtle body/carb. You use the standard drive shaft.
    2. I used a non-a/c dash. I dont like the center vent. There are vents on either side of the package tray. I have custom lines to the compressor that will soon be installed.
    3. Exhaust is kit tubes from summit cut and welded to fit and a Magnaflow muffler.
    Frustratingly, the following week after I took the completion photos, I pulled the motor. I was buring about a quart in 100 miles. Could not figure it out. I sent it back to the machine shop. Someone there did not read the instructions and forgot to install the PCV baffle in the intake. Making a couple modifications while it is out. Unfortunatly, I will miss a car show next week and will have to use my substitute car. Hope to have it on the road in a couple of weeks. Some AC hoses and a stereo should complet the project.
    Micah
    DGD likes this.
  6. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    Very impressive. :thumbs2:
  7. Ryan Whiteside
    Ryan Whiteside MCCI SC State Rep
    Upstate, South Carolina
    1969.5 Ford Maverick 302
    Jaw dropping example of a maverick. The time line of the build from start to finish and the details listed are truly inspiring. Is there a way you could take get a picture of the tail lights at night? Great job man.:thumbs2:
  8. mavgrab302
    Beautiful...
  9. 71Mavrk
    71Mavrk Member
    Nevada
    Thanks Ryan. As far as the tail lights, are you looking to see how bright they are or how they sequence? It might take me a bit to get some photos at night. With the engine out, I'm hesitant to connect the battery.
    Micah
  10. tody
    tody Member
    cologne, germany
    awesome car, awesome build.
    the picture of the fuel pump in the 19 gallon tank gives me a good idea on how to convert mine!
  11. 71Mavrk
    71Mavrk Member
    Nevada
  12. Ryan Whiteside
    Both really. No rush. Would be hesitant myself to hook the battery up.
  13. Supersnake69
    Supersnake69 Member
    1972 Ford Maverick
    Wow!!! that's pretty amazing! Question. Those turn signal lights in the grille don't look stock? Are those LEDs? I love that idea over the original sidemarkers.
  14. 71Mavrk
    71Mavrk Member
    Nevada
    Yes, the fronts were modified also. Below is a link to an old picture of what I did. I later upgraded to the better LEDs that I used in the tail lights. I wanted something brighter like the modern cars running LEDs in the hope that it will prevent someone from running into me. Standard 1157 bulbs are 32/3 candle power. One 48 LED panel puts out over 48 cp of a much whiter light. It is actually surprising how bright they are.
    http://mmb.maverick.to/media/led-front-turn-signal.17410/
    Micah
  15. Supersnake69
    Supersnake69 Member
    1972 Ford Maverick
    That's really clever! Was there any major hurdle with using LEDs with a stock harness? From what i have heard LEDs draw less power but the wiring is a bit more "complex" but seeing as cool those look (and saftey due to brightness) I may just have to look into that.
