sheet metal thickness
Discussion in 'Cosmetic' started by jhossrock, Mar 21, 2006.
  1. jhossrock
    jhossrock Member
    scranton,pa.
    1972 4dr. maverick
    hello, i will be welding in some patches on my maverick. my questions are, what gage metal do i buy that is easy to work with. also can i use a propane tourch to soften the metal or do i need something more powerfull?
  2. RabidCustoms
    22 gauge will do you fine for most areas of the mav.
  3. Tom Laskowski
    Tom Laskowski Member
    Bay Area,California
    (3) 71's,two V-8's and one 200 cid
    Propane? for what? Are you doing a cook out?
  4. jhossrock
    jhossrock Member
    scranton,pa.
    1972 4dr. maverick
    no tom, i never worked with sheet metal. but i do know that if you heat metal up it should soften it. i just would like to know how much heet? i don,t want to buy something that i don,t need. thank you for your reply.
  5. cyclonewill
    cyclonewill Member
    SandSprings, Oklahoma
    Just my :2cents: : I use 20 gauge on most repairs, it's easy to work, but plenty strong, (and not as easy to burn a hole in welding it up.) just a hammer and dolly (and some patience/ practice) will get you nice and close. good luck!
  6. Mavaholic
    Mavaholic Growing older but not up! Supporting Member
    putting that much heat will soften the metal but it will also warp it. It just depends on where your making the repairs. For external repairs, I would not take a torch to it. For shaping floor pans, I have use a tourch to persuade metal to see things my way. I would think a propane tourch would work for small areas but I"ve never actually tried it. I have a oxy/ac set.
  7. jhossrock
    jhossrock Member
    scranton,pa.
    1972 4dr. maverick
    thanks for the info. i first have a big job to do. the motor in our escort ate a piston. i have the new well not new motor, just need some warm days to get started. next time i,am down the garage i will take a picture of the blow up and send it.
