Straight 6 250 | EGR Spacer needed
Discussion in 'Parts Interchange' started by MSMLuna, Jun 21, 2018.
  1. MSMLuna
    MSMLuna Member
    Ft. Bliss, Texas
    1975 Mercury Comet
    I was replacing the gasket and ended up splitting the spacer where the bolt is. Need replacement
  2. Krazy Comet
    If it isn't needed to pass emissions, I'd just do away with it.
    Crazy Larry likes this.
  3. MSMLuna
    MSMLuna Member
    Ft. Bliss, Texas
    1975 Mercury Comet
    Would that work? It's got tubes attached to it and stuff
  4. Krazy Comet
    It isn't needed, not on engines before '73 or so.. BUT if you're not sure what the function of the tubes(feed from exhaust manifold) and stuff(vacuum lines)are, maybe better to replace it.
  5. MSMLuna
    MSMLuna Member
    Ft. Bliss, Texas
    1975 Mercury Comet
    And the carburetor is just able to bolt onto the intake manifold?
  6. Krazy Comet
    Most engines used a solid spacer, maybe with vacuum tap under carb. When EGR was used usually it's spacer replaced the previous type. For a 250 I dunno if said spacer is necessary to set height or angle of carb mounting.
  7. rthomas771
    No it needs the adapter. The 250 RBS carb adapter has wider bolt pattern than the 170/200 carb adapter. If you want to do away with the EGR then you will need to plug the exhaust manifold
    MSMLuna and Krazy Comet like this.
  8. MSMLuna
    MSMLuna Member
    Ft. Bliss, Texas
    1975 Mercury Comet
    That helps a lot! Next question is where can I get that part and the plug for the exhaust manifold?
  9. rthomas771
    Got mine at the hardware store
  10. MSMLuna
    MSMLuna Member
    Ft. Bliss, Texas
    1975 Mercury Comet
    The carb adapter?
  11. MSMLuna
    MSMLuna Member
    Ft. Bliss, Texas
    1975 Mercury Comet
    You got the adapter at the store too?
  12. rthomas771
    You asked where I got the plug for the exhaust manifold and I said the hardware store. I got the carb adapter at the junkyard off a 71 Maverick Grabber with a 250 inline six.
