Ticking
Discussion in 'Technical' started by 289, Jun 28, 2014.
  1. 289
    289 Member
    Prescott Wisconsin
    73 grabber
    Okay so here is my situation, i was driving then i started to hear a "Tick" or "Tap" sound from engine. Sounded like it was from the #8 cylinder underneath the valve cover. So i took off both valve covers and inspected the valve train, Nothing was loose, bent, or out of the ordinary comparing the #8 cylinder to the others. But i tightened the lash on the valves again just in-case. After all that it still ticks. what could it be? Bad lifter? Maybe wiped cam lobe? Leaky exhaust manifold gasket? Something with ignition? Any advice or opinions appreciated:)
  2. COMETIZED
    COMETIZED Member
    Florida
    70 Mav. 74 Comet
    ticking ??
    Often the sound appears to be a "tick" .. it could actually be a small exhaust
    leak .. I've encountered this and I found my exhaust manifold had a rupture.
    Just a thought ! Luck with the tick ..
    Cometized
  3. Craig Selvey
    I concur....sounds like an exhaust leak.
  4. m in sc
    m in sc Member
    rock hill sc
    we had a similar thing, was worst case scenario, piston was cracked. not saying thats what it was but if its still there after you check everything else, consider it a possibility. and it sounded dead like a valve or small exhaust leak. [​IMG]
  5. Moneymaker 1
    Panama City Florida
    Could be a torque converter nut backing off and hitting the block plate or as in my case long ago, the inspection cover, hunted that noise for a while.
  6. simple man
    simple man Member
    Bunnell,Florida
    Put #8 cyl on TDC and see if you can press the rocker arm down by pushing on the pushrod side of it. You can? The lifter has collapsed. If you can't, crank the engine (or start it) and see if both valves move up and down the same amount. If they move equally, your valvetrain is most likely Ok, and the tick is an exhaust leak. :)
  7. dan gregory
    dan gregory Member
    chesapeake va
    1970 maverick
    Does it get louder if you rev the engine,like most on here,if it does then either a lifter or a cracked piston skirt.
  8. 289
    289 Member
    Prescott Wisconsin
    73 grabber
    Sorry bringing this post back up again, just got back from a 50 day trip in the arctic circle.
    Here are some more symptoms I noticed, it backfires more then usual and the ticking is very loud when I accelerate but when I cruse I almost can't even hear it. I also want to say ticking is getting louder (not driving it too much because I want to figure it out so I don't blow anything up)
    Haven't been able to look at her too much since I got back, but I'll give it a try today.
    Thanks for the help, I really appreciate it.
  9. Pintony
    Pintony Member
    St louis
    Pinto
    Broken valve spring.
  10. Pintony
    Pintony Member
    St louis
    Pinto
    Put a bottle of LUCAS in it! It will be OK!!!!:p
    m in sc likes this.
