Trunk floor rusted
Discussion in 'General Maverick/Comet' started by 68smurfstang, Jan 12, 2022.
  1. 68smurfstang
    68smurfstang Member
    SC
    Ok, I have swiss cheese for a trunk pan. I have read the posts on how to use por 15 and other products. We all know that replacing the sheet metal is the best way. The question I have is has anyone successfully used a complete mustang pan, or used the mustang drops, and front and rear sections? I have a right hand trunk floor and it looks close. I also have an extra new mustang gas tank.
    I found a donor Maverick but might be easier to just fit some new metal.
  2. 68smurfstang
    68smurfstang Member
    SC
    Forgot to mention that the donor Maverick is a 4 door. Wonder if the trunk is the same? Also are the rear floor pans and seat the same?
  3. ike72com
    ike72com Member
    Charleston SC
    I,ve seen rusty trunk in a galaxy convertible. Poor guy had carpet in trunk.
    My comet had a few hole in low spot but not bad enough to worry but i did
    did consider cutting square hole, framing and dropping in 70 mustang tank being i needed a new tank anyway.
    Just a thought.
  4. 68smurfstang
    68smurfstang Member
    SC
    I definitely considered putting a mustang tank in it. I bought the 4 door donor car, and it turns out that the trunk pan is in great shape. It also has really nice floor pans. FYI, the 4 door floor pan is different. It is a little longer, but will work with slight modification. It has a nice trunk lid, but it is different than the 2 door, as well as the quarter extensions. I would of thought they would have been the same.
  5. ike72com
    ike72com Member
    Charleston SC
    Your donor car might be in better condition rust wise then many drivers on road today.
    Are you planning on having ugly spare tire, tools and other junk in trunk or are you showing your trunk at shows?
  6. 68smurfstang
    68smurfstang Member
    SC
    Ike 72, I plan on driving this car. I have 2 mustangs that are show worthy. I am in the process of cutting the trunk pan from the donor car. Just about got it.
    Although I haven't verified this, I believe the metal is thinner on the Maverick than the mustang.
    I am cursed with being anal about everything I do. I wouldn't be able to stand it if I don't repair it to the best I can.
    ike72com likes this.
  7. ike72com
    ike72com Member
    Charleston SC
    Please! please! Pic of your mustangs!
  8. 68smurfstang
    68smurfstang Member
    SC
    1968 convertible, 302 automatic. 1970 Mach 1, 352 Windsor, mild cam, 4r70w, classic air, Edelbrock pro Flo 4.
    gator25, Jaybee and ike72com like this.
  9. 68smurfstang
    68smurfstang Member
    SC
    Oops 351 Windsor on the previous post.
    Got the donor trunk pan out and media blasted. Allot of work, but it will be worth it.
    ike72com and 71gold like this.
  10. ike72com
    ike72com Member
    Charleston SC
    Nice cars you have 68smurf and you,re doing great work. Ohh and we have something in common. Heres mine i just painted.
    gator25, Jaybee and mojo like this.
  11. 68smurfstang
    68smurfstang Member
    SC
    Thanks, I have done 6 of these old mustangs and each time I say it's the last one. Really getting tired of breathing all the nasty stuff associated with the restoration process, but I still have a passion for it. Then the Maverick showed up. Go figure!
    Your 70 mustang looks good. Do you have the 351 Cleveland? Did you use base clear?
    Our son did live in Charleston for a while, just off the ravenel bridge.
  12. ike72com
    ike72com Member
    Charleston SC
    Number 6? Yep you,re an addict...hahaha!
    408w in the stang. Painted base/clear.
    I,m on north end of mt pleasant.
