V8 frame bracket
Discussion in 'Technical' started by 76LuckyMav, Mar 1, 2024.
  1. 76LuckyMav
    76LuckyMav Member
    Pennsylvania
    76 Ford Maverick 4 door
    What way does the v8 brackets face, the ones I purchased from autokrafters have one side that pokes out further than the other side. If anyone knows or has a picture of your current set up, I would appreciate it, thank you, Brady.
  2. dyent
    dyent Member
    vancouver bc
    The "Flat" side faces the front of the car, bulge towards firewall and tang towards bottom.........
    David
    76LuckyMav likes this.
  3. 76LuckyMav
    76LuckyMav Member
    Pennsylvania
    Thank you so much, David, appreciate you !
    dyent likes this.
  4. dyent
    dyent Member
    vancouver bc
    You are very welcome!:)
    David
  5. Craig Selvey
    Borrowed from another mmb member here.
  6. 76LuckyMav
    76LuckyMav Member
    Pennsylvania
  7. 76LuckyMav
    76LuckyMav Member
    Pennsylvania
    Got the engine into its new home yesterday !
  8. 76LuckyMav
    76LuckyMav Member
    Pennsylvania
  9. 76LuckyMav
    76LuckyMav Member
    Pennsylvania
    4 speed toploader swap as well.
    Krazy Comet, Shorty and dyent like this.
  10. 76LuckyMav
    76LuckyMav Member
    Pennsylvania
    I'm assuming the 289 is a bit lighter than the 250 inline 6. The car sits a little higher in the front than it did before. I would've bet the car sat lower, not in my case.
  11. Krazy Comet
    A 289 with aluminum intake likely weighs a little less than the 250.
    TeeEl and 76LuckyMav like this.
