ok i have a bad virbration from the back drum brakes. but its only when i hit the brakes or the e brake. they have new shoes on them.. are the drums out of wack?
For sure, your drums are "out of round" This is normal. Most shops will turn these for you for $5 a pop or so, but there is a chance that they could be too thin (turned too many times) New drums are usually less than 50$ a piece. If the vibration isn't too bad, and doesn't get worse, you can usually wait till you have the $$$ or time to fix it
