What are the stock colors of a 1971 maverick grabber
Discussion in 'General Maverick/Comet' started by Mavit, Aug 14, 2014.
  1. Mavit
    Mavit Member
    Prince george bc
    two muatangs ansd one comet
    I thought My car was Calypso corral but I was told that color was not a 1971 color ! what was the stock Red called !
  2. Pintony
    Pintony Member
    St louis
    Pinto
    Mavit likes this.
  3. Dave B
    What's the paint code on the data sticker?
  4. Paul Masson
    1971 Grabber
    I'm gonna take a guess and say Code: "3" Bright Red??
  5. Mavit
    Mavit Member
    Prince george bc
  6. Mavit
    Mavit Member
    Prince george bc
    You are correct it is Code 3 !
    Paul Masson likes this.
  7. Pintony
    Pintony Member
    St louis
    Pinto
    Most of the colors on these 40+year old samples are really off the mark of the original color.
  8. spxer
    spxer Member
    Raleigh NC
    guess mine was dark green irid was a dark green /metallic
  9. h2o
    h2o Mad Mav Man
    mexico city
    1973 ford maverick gt 289 v8
  10. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    My car is Bright Red - Code 3. It definitely has a lot of Orange in it (I watched it being mixed) but not Orange like Calypso Coral.
    Mavit likes this.
  11. Mavit
    Mavit Member
    Prince george bc
    Yes your car is the same color as mine, I was misinformed on the color when I bought my car from the dealer, this is the first time I had a chance to compare the Body Code to a chart!
  12. mavmania427
    mavmania427 Member
    Nipomo, CA
    1972 Maverick Grabber, 1972 Comet GT, 1971 Comet 4-door, 1971 Maverick 2-door (RIP), 1976 Maverick 4-door (RIP), & 1972 Maverick Grabber (RIP)
    Did your paint vendor match the factory "bright red" color? Is there a certain spec that they can match or do they match a sample?
  13. dmhines
    Cumming, GA
    My car is painted factory Bright Red. Body shop use the formula out of his book and made a two-stage paint out of it.
    Here is what it looked like before restoration:
    After
    rayzorsharp and Paul Masson like this.
  14. Mavit
    Mavit Member
    Prince george bc
    The paint shop said he could match the color by taking a sample from the in side of the trunk! he never gave a color!
    He said codes are hard to match because the paints are not the same any more!
  15. dmhines
    Cumming, GA
    Are you painting the entire car?? Or is he making Touch-up paint? If you are painting the entire car then just have him use the color mix supplied by his chosen paint supplier Converting a single stage mix to a 2-stage mix may not create a 100% perfect original color .. but it should be close enough. I assume you are going to do base coat / clear coat.
