Doug Thorley Headers Installed....
Discussion in 'Technical' started by Craig Selvey, May 14, 2007.
  1. Craig Selvey
    I have the headers installed. I only ran into one large obstacle...and that was due to me installing these on RHS Pro-Action Heads. On the driver's side I had to make room for the spark plugs as they come out at a different angle than stock heads. I had to "ding" and heat up and "persuade" the tubes for clearance. Once I did that....I sent them in and had them ceramic coated. That required installing and removing about 8 times....especially the driver's side. I also had to grind off part of the mounting flange on both sides in order to get a socket in to the spark plug holes. Again.....these were problems only because of the heads I installed.
    Otherwise....they went in (and out...Ha, Ha) very easy. Car is at the muffler shop right now...but I can post these pictures. Driver's side required a very small "crease" to clear the pitman arm...but not bad at all.
    See pictures: (this is taken with the car in a full left turn)
  2. Craig Selvey
    Here are some pictures of the driver's side header after modifications in order to clear the spark plugs.
  3. CornedBeef4.6L
    CornedBeef4.6L no longer here
    no longer here
    No headers fit those heads. There are on my brothers maverick. I have the easy side made. 1 and3/4 primaries 3.5 collector. Now I have to do the drivers side.
    Lookin good!!!!!
  4. 69 ina 1/2
    69 ina 1/2 Fox body nut!!!
    Smog Bernardino, Ca.
    Ah, thats great Craig!!! Good, clean install :yup: . Exhaust looks great as well. (y)
  5. MikeG747
    MikeG747 Member
    Arkansas
    Thanks for posting Craig! Great info.(y)
  6. A_Bartle
    A_Bartle Stallion Dreamer
    Michigan's Thumb
    1976 Yellow 2-door Maverick
    Craig, that car is going to look "amazing" when you get it done. Have you updated the photos on your web site yet?
  7. Craig Selvey
    Nope....too busy getting the car done. "Gots" to get in done for D.C.
  8. grbmaverickmo
    Aquashicola, PA
    Fit better then they did on my car. Cars lookin good
  9. Dave B
    Awesome!! I knew they would work! Car looks Awesome!!
  10. Max Power
    Max Power Vintage Ford Mafia
    St. Paul, MN
    LOL, I would switched heads.....I guess I'm lazy.
  11. shaunh82
    shaunh82 Member
    Washington NJ
    71 Pinto sportsroof
    Craig, what size exhaust are you running?
  12. Craig Selvey
    2 1/4"
    Pictures to come later.
  13. streetrod77
    streetrod77 Member
    Memphis,Tenn
    77 comet
    Are these the shorty style headers?
  14. Craig Selvey
    yes they are the shorty style
  15. streetrod77
    streetrod77 Member
    Memphis,Tenn
    77 comet
    Okay so we are talking great ground clearence right. I have lowered my car 3 inches & I want to go down some more, so long tubes where out the question. I wounld like to be 4 inches off the ground. Right now i'm around 7 but thats because of the 2 1/2 exhaust tubes. With headers I was thinking of going with oval tubes for better ground.
