Not all Maverick Tail-lights are the same.
Discussion in 'Technical' started by Craig Selvey, Sep 6, 2005.
  1. Craig Selvey
    Many of you may have noticed that not all Maverick Tail-lights are the same. I believe it is the 1970 tailights that have a bigger REVERSE lens than the 1971-1977 units. I have heard many of you discussing swapping to the early style because you prefer the look of the bigger reverse light. The early style is on the bottom.....the later style is on top in this picture. But...besides the different look....there is a physical difference as well. The later style has 2 additional screws to hold the lens on with...and these are located where the indentions are located in the lens near the reverse light. I have pointed out these indentions with the yellow arrows. While the top lens will fit any tail-light housing, the bottom lens will only fit the later style housing if you leave off the two screws. You can see the later style tail-light housing in this post . This tailight housing does not have the two screws located under and above the reverse light lens.
    Just something to keep in mind when you are swap meet/junkyard shopping.
    P.S. As a side note....both of these lens had the EXACT same part number cast into it.
  2. CornedBeef4.6L
    CornedBeef4.6L no longer here
    no longer here
    I have a set of NOS tail light lense and they are the smaller variety but I checked anyway:cry:
  3. M.A.V.
    M.A.V. Yep,my real initials.
    Macon,Georgia
    Hmmm...I`ve got a 69.5 ,a `71, and a `72 and never noticed that.:)
  4. Rick Book
    Rick Book Member
    Thailand
    Missing my old '70 Maverick
    Good info. Thanks!
  5. 71gold
    mike,
    i need to look at the 691/2 lens. give me a call...frank...:bouncy:
  6. NICK DOMINICK
    Burke, Virginia
    The tail light bezels have a small difference too. The drainage holes on the bottom of some are holes and some are slots. Don't have any pictures but if you get anal with your car you would want them to match. You never know when you are going to be laying on the ground looking up at the difference wishing they matched.
  7. Scotty P
    Scotty P Member
    santa rosa, ca
    Are the '70 lenses hard to come by? I was planning on (yikes) drilling a hole in mine to install my battery cutoff switch. My thoughts were I could always replace the lens if I wanted to remove the switch.
  8. Craig Selvey
  9. Jamie Miles
    Alto, GA
    I've had a few
    In that case, the passenger tail light on my car has been replaced. Must have been when it was lightly rear ended in 1980.
  10. Ford_Motorheads
    Ford_Motorheads Ford Addict
    Phoenix, AZ
    1961 Falcon, 1967 Ranchero, 1969 Gran Torino GT, 1974 Ranchero GT 1976 Mustang Stallion, 1977 Mustang coupe, 1978 Mach 1, and 2 1978 Cobras
    Thanks for the info, I would have probably never noticed that. :yup:
  11. rayzorsharp
    Geez...my tail lights don't look anything like either of those:huh: :confused:
  12. Ford_Motorheads
    Phoenix, AZ
  13. highhillbilly
    highhillbilly Member
    virginia
    1969.5 maverick
    on my 69.5 ,they are the big ones and have slots for drains
  14. Earl Branham
    Lugoff, SC
    Mine too!!!!!!!!:wave:
