Restoring tail-light housings
Discussion in 'Technical' started by Craig Selvey, Sep 6, 2005.
  1. Craig Selvey
    Sometimes finding really nice taili-light housings can be difficult. If the car has any rust at all allowing moisture and debris into the trunk...the taili-light housings will be rusty and nasty looking on the side that faces into the trunk.
    Over the years....I have seen many cars that had the factory trunk speckle paint applied AFTER the car was fully assembled. This means the tail-light housings, side markers, and all wiring will have speckle paint sprayed all over it as well as the trunk. I have been quick to discard these parts as they had been "painted" and don't look good in my opinion. I decided to take a set of them and see what I could do with them.
    In this before shot....one can see that the rest of the housing looks really presentable. The only "bad" part is where it was painted. If one thinks about it....this is the only part that was painted...so it is the only part that was subject to the elements if it had been left "bare". In a way....it was sealed shut at the factory!!!
  2. Craig Selvey
    I bought a spray can of aircraft paint striper at an auto body suppy store. Simply sprayed the back of the housing to let it soak. After 10 or 15 minutes....I scraped off the paint. I then sprayed the tail-light housing again and used steel wool to give it a final cleaning. A little soap and water and this is what you have....a really nice tail-light housing worthy of a show vehicle.
  3. fan2488
    fan2488 Member
    spring,TX
    1969.5 maverick, 1972 grabber
    sure makes a difference. looks good. thanks for the tip
  4. skate1274
    skate1274 Member
    St.Pauls North Carolina
    1974 mercury comet GT
    got the same syuff to take five coats of paint off my tail lights .....that stuff is freakin awsome !:)
  5. maverick75
    :wow: cool tip
  6. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    Nice job Craig,,, is this for the orange car?? Are you working on it????
    Dan
  7. Craig Selvey
    Oh yeah!!! Pictures coming soon. I have lit a fire that burned out about 3 years ago. Finding parts you removed 5 years ago is fun. Easier to raid the "for sale" parts stash than it is to dig and find where I put the other parts.
  8. littleredtoy
    littleredtoy Seth
    North Carolina, Triangle Area
    '74 Comet GT
    I did the same with the plastic comet taillight housings. Afterwards I used grey primer to simulate the original gray plastic. They were swirled and faded for some reason-perhaps from age. Funny that the Mavericks/Pintos were metal and Comets/Montegos were plastic.
    Seth
  9. Maverick Man
    California
    wow if i go to a show and they look in my trunk to see how clean my tail-light housing are to determine if my car should win or not.... i don't ever want to attend that show again :p
  10. Craig Selvey
    I wouldn't normaly go to this extreme....but I have seen the competiton!! Got to "step up"!!! :D
  11. littleredtoy
    littleredtoy Seth
    '74 Comet GT
    Hmmm.....referring to someone named Dan?
  12. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    I'll have to double check when I get home from work but aren't they Gold Cadmium from the factory?
  13. Craig Selvey
    Looks like a bright aluminum type color.........not sure what you would call it.
  14. Mavaholic
    Final coating shouldnt matter. We dont have a concours catagory.
  15. dmhines
    Cumming, GA
    Yup ... I was bugging ... they are silverish :) ...
