Are all Oil pans created equal
Discussion in 'Technical' started by Chinguschild, Mar 4, 2008.
  1. Chinguschild
    Chinguschild The Bass Player
    Orcutt, Ca
    71 Grabber
    I know (atleast I think I know) I am going to need a front sump pan for the v8 conversion. But will just any pan work. I am buying an aftermarket pan (roller block i bought didnt have one).
    • Do you guys run aftermarket pans? If so which ones?
    • Will any front sump work?
    • Anything to look out for?
  2. maverick1970
    maverick1970 MCG State Rep
    Missouri
    Are you looking for a stock or extra capacity pan?
  3. Chinguschild
    Orcutt, Ca
    71 Grabber
    Anything that will fit really. My brother and me are build a 347 Stroker so make a suggestion based off of that.
    An extra capacity pan would be nice!
  4. eddie1975
    eddie1975 Windsor Specialist
    Martinsburg, WV
    sold
    if you get an extra capacity make sure you get a proper pick up
  5. Chinguschild
    Orcutt, Ca
    71 Grabber
    still doesnt answer my question.
    will any front sump work?
  6. eddie1975
    Martinsburg, WV
    sold
    far as i know you shouldnt have a problem
  7. bmcdaniel
    I bought Summit's front sump pan for about $40. Have it on my 5.0. IIRC front sump pans were all the same except for some van applications.
  8. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    NOT ANY FRONT SUMP WILL WORK!
    need to check on the width of the pan if you go with an bigger than stock pan. You can (cause I did) get into clearance issues
  9. don graham
    I use a Moroso 7qt. and haven't had any clearance problems. I've heard theat the chrome pans, while looking nice, hold the heat more. Same on the tranny pans.:)
  10. BadMav7086
    BadMav7086 Member
    Tucson, AZ
    1970 Maverick drag car
    i agree check the width we got one and it was too wide so we had a friend of ours cut it and weld the corners up so we no longer have a problem.
  11. maverick1970
    Missouri
    Milodon 30925 pan and 18375 pick up fits great.
  12. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    I have run Moroso 10" sumps without issue.
    The only pans you have to watch out for is the 'kick-out' type pans.
    Other than those, pretty much any front sump works.
    Now, here's what you look for:
    Milodon kick-outs work fine.
    If you look closely at the Milodon, you will see that the wide part of the pan slopes down, kinda triangular.
    Now think about a Cobra style kick-out.
    They kick-out in a rectangular shape.
    What you might call 'boxed'...
    Those type kick-outs don't fit.
    Oh yeah, chrome does hold in heat.
    Dark colors like black and blue are best for heat dissipation.
  13. bmcdaniel
    But John, I heard you were trying to use a backwards Chevy pan.
  14. Chinguschild
    Orcutt, Ca
    71 Grabber
    Well I found two that will seem to work. They are stock 5 quart, wet sump, chrome (didnt want that, oh well) and are stroker clearanced. Thanks for all of your work
  15. PINKY
    Louisville, Ky.
    1970 Ford Maverick
    not trying......I did :drive:
