Mustang mirrors on Maverick
Discussion in 'Parts Interchange' started by VatoLoco, Oct 28, 2008.
  1. VatoLoco
    VatoLoco Member
    San Juan Capistrano
    1974 Maverick
    I was browsing through this online catalog for a Mustang 1965-1973 and i was looking for some mirrors that might fit my maverick and was wondering if the 1973 Mustang Mirrors would fit on my 1974 Maverick?
    Here's the link http://npd.dirxion.com/Main.asp go to the scroll bar on the left and scroll down to mirrors the ones i'm thinking of are on the 2nd page.
  2. newtoford
    newtoford Member
    New Castle Delaware
    the mirror "stand" which is the piece between the cup and door is usually diffrent between mustangs and mavericks since the door is shaped diffrently
  3. fan2488
    fan2488 Member
    spring,TX
    1969.5 maverick, 1972 grabber
    i used 74-78 mustang mirrors. i have remote on both sides.
  4. mean_maverick
    i believe the 71-73 mirrors to be the same. the 74-78 will work just fine, just has a smaller base. you can also use the sport mirrors features on Granada's and Monarch's as the base is the same size but is squared at the front of the base instead of pointed like the Maverick/Mustang mirrors
  5. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    You need Mustang 2 mirrors... 74-78. These aren't the same, but work.
    The earlier ones have different bases... 69-73.
    Generally speaking, every car has a different base, to match the contour of the door and keep the top portion level. Most of the tops swap fine.
  6. paxtond
    paxtond Member
    Ontario
    1971, 1976 Comets
    The Granada ones are not the right angle, not the same as the Mav-Com. Close but off.
    Mustang II and Pinto sport mirrors are the right angle but do have smaller bases than the Mav-Com.
    I found out the hard way.
  7. splatt
    splatt Member
    Claymont, Delaware
    1975 grabber, 53 Ford Mainline Gasser, 61 Porsche 356
    anyone know if sport mirrors off a 74 cougar would go on my 75 mav with any issues? says they'll fit 71-74.
  8. paxtond
    paxtond Member
    Ontario
    1971, 1976 Comets
    I believe the mid 70's Cougars are the same as Granada / Monarch i.e. different base angle and will not fit properly.
  9. splatt
    splatt Member
    Claymont, Delaware
    yeah, looking at the pics i can see the difference. bummer. oh well. thanks
  10. ratio411
    ratio411 Member
    Pensacola
    The whole issue is that every different body style has it's own unique sport mirror base. The tops are the same for the most part.
    I have compared a few early Stang (69-73) in hand, and they are obviously off. The early Torinos are WAY off. I have seen some late 70s full size (LTD, Merc) that look close, but I haven't compared those 'in hand'.
    Your best bet is to get used Maverick/Comet units that have damaged top portions. That way you get them cheap... Then transplant good tops off of a cheap donor... From an undesireable model donor, so the cost isn't high and the donor can often be found in a local wrecking yard.
  11. splatt
    splatt Member
    Claymont, Delaware
    oooooh yeah, thats a good idea. thanks!
