Poly Bushings for the rear shackles
Discussion in 'Technical' started by olerodder, Apr 8, 2013.
  1. olerodder
    olerodder Member
    NorCal
    Has anyone used Poly bushings for the rear shackles and if so where did you get them.
    Mustang bushings won't fit because they are 1-3/8" OD and the Mavericks are 1"OD...................any suggestions.
  2. 55crownvic
    55crownvic Member
    colorado springs
    You might try to find a company that makes leaf springs in your area, and see if they can get them for you.:huh:
  3. olerodder
    olerodder Member
    NorCal
    Have already done that with everyone saying they either can't find any or know one they know makes them:(
  4. jm16
    jm16 Joe Marino
    Oak Park, MI
    1975 Comet GT
    I'm pretty sure I have an extra pair that I'm not going to use. Let me check and I'll pm you in a few minutes.
  5. tody
    tody Member
    cologne, germany
    luckily they cross over to an odd early cougar bushing.
    i ordered from mustangsunlimited, part no. 2005RG
    but i'm sure that wccc also carries them.
    a problem i ran into was that the sides are not as wide as the rubber bushings, so my shackles had some play to each side. i put in a washer on each side, fits now perfectly.
  6. rthomas771
    The early Mustangs used the same bushings as the early Falcon/Comet. Don't know what the Fairlane used.
  7. mercgt73
    Nice find, Tody! Gonna save that one for sure. :tiphat:
  8. Dave B
    Too bad they are Red....
  9. olerodder
    olerodder Member
    NorCal
    Tody, :tiphat: off to you, I've been looking everywhere and talked to half the aftermarket chassis shops on the other side of the Rockies.................no one
    new, even Energy Suspension.
    You are a live saver...........Thanks!
    P.S. I did order them from Mustangs Unlimited and should have them by Friday.
  10. olerodder
    olerodder Member
    NorCal
    Dave, my car is just an Ole race car so it doesn't need to look pretty just go fast and straight..................................besides at least on mine I think Red will look nice against all of the black.
  11. olerodder
    olerodder Member
    NorCal
    I couldn't find any information on either the early Falcon or Comet, but the ones Tody suggest are the perfect OD............................Energy Suspension doesn't make any Poly bushings for the early Falcon or Comet..............or Maverick, but make tons for the early Mustangs............................Go figure!
  12. olerodder
    olerodder Member
    NorCal
    If the early Falcon/Comet use the same bushings as the early Mustangs they are 1-3/8" OD.............and the Maverick is 1" OD.
    If you have a lathe you can freeze the Poly bushings and turn them down...but
    they need to be frozen..................I've got the freezer but not the lathe.
  13. Dave B
    I'm building a Black car...I guess I'll order some anyways.. (y)
  14. rthomas771
    You got me thinking...I might had cut the O.D. on the Mustang bushings down on a lathe, but I didn't freeze them. I do know that I cut them down on a lathe to fit a 2" wide spring. The Mustang spring was 2-1/2" wide. Heck...we're talking about what happen in the mid 80's and I did what had to be done and didn't think much more about it until now.
  15. Dave B
    I ordered some also....:(
