Power to non-power steering
Discussion in 'Technical' started by boss9, May 10, 2006.
  1. boss9
    boss9 Member
    Akron,Ohio
    77 4-door 250 I6
    Looking for the "least expensive" supplier for the manual steering adapter to eliminate the control valve.
  2. 71gold
    this is what i used from "mustang unlimited", check web site for price.
    ...frank...:bouncy:
  3. scooper77515
    I really want to do this, and it is only $100-150 depending on where you get the part...I just can't believe how easy everyone says it will be to turn.
    If I find a non-PS car and turn it while sitting still, will it be a decent estimate of comparison for how easy mine will turn without PS? I got a friend in the 'hood who has 3 cars (one is a 70), and at least one should be nonPS... :huh:
  4. 71gold
    the "adapter" i got was around $50...frank...:bouncy:
  5. scooper77515
    Even BETTER! For that price, I can try it out and then take it off if I don't like the feel of it.
    It HAS to be better than the swimming side-to-side play of these poor power steering systems... :huh:
  6. scooper77515
  7. scooper77515
    What exactly does the $65 kit do to the original system? Can I get the parts from the hardware store and do it myself?
  8. boss9
    boss9 Member
    Akron,Ohio
    77 4-door 250 I6
    :tiphat: Thanks Frank,
    That's the best price I've seen. How difficult was the job ? I have the tool to remove it.
  9. 71gold
    not bad, just messy. i removed the pump,mounting bracket, hoses and cyl. i got the end piece off a parts car and built up a unit. that way i saved the whole set up in case someone wanted it later...frank...:bouncy:
  10. NAFORD302
    NAFORD302 Member
    SILEX MO
    77 FACTORY V8 AC CAR
    Does Anybody Know What Year To Get Some Places It Shows 65&66 And Then 67 Up Please Let Me Know Thanks
  11. 71gold
    as a rule of thumb, i get mustang parts for a '73...frank...:bouncy:
  12. Grabber5.0
    Grabber5.0 Gear-head wannabe
    Kansas City, MO
    71 Grabber
    I'm pretty sure two of those pieces pictured hold the ball stud securely, so I doubt it. If there is any movement in that stud, you will have very sloppy steering. The ultimate goal of that kit is to remove the hydraulic system from the control valve and secure the stud that links it to the pitman arm. $65 is a pretty cheap conversion.
  13. NAFORD302
    NAFORD302 Member
    SILEX MO
    Where Does It Say $65.00 I Dont See That
  14. scooper77515
    On my thread where I put the two links, the top link goes to a $65 kit ($64.95 actually, if you want to get picky :D ) and the bottom link goes to the $165 kit.
  15. NAFORD302
    NAFORD302 Member
    SILEX MO
    Thank You It Would Not Open For Me But Now It Is Thanks A Lot
