fuel gauge whacky!
Discussion in 'Technical' started by mashori, Feb 18, 2009.
  1. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    So when the gas tank is totally filled the gauge shows about 3/4 full and when the tank is almost totally empty it shows 1/4 full. When the car is off it falls all the way to zero so I know it is functioning but it's just off.
    what's the reason for it and how can I fix it?
  2. random hero
    random hero 1972 ford maverick I6
    hudson valley
    1972 maverick
  3. A_Bartle
    A_Bartle Stallion Dreamer
    Michigan's Thumb
    1976 Yellow 2-door Maverick
    Sounds like the float on the sending unit needs to be replaced....
  4. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    any recommendations where to get it from?
  5. maverick1970
    maverick1970 MCG State Rep
    Missouri
  6. A_Bartle
    Michigan's Thumb
    If you google it, I'm sure you can find several suppliers. They might not list "Maverick" but I'm sure most floats for Ford products of that era would work.
    Here is a great source to read regarding sending units:
    http://www.gudim.com/ReplacingCorkFloats.html
    Here are some floats from some Mustang parts stores:
    http://johnsmustang.com/Parts/details-5899.html
    http://www.parts123.com/parts123/yb.dll?parta~partsort
    http://www.mustangsunlimited.com/itemdy00.asp?T1=240075+01
    PS: I had to replace the float in my '76 for the same reason.....
  7. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    thanks, awesome links!
    is it hard replacing the sending unit if I ended up replacing the whole thing?
  8. A_Bartle
    Michigan's Thumb
    Actually it's very easy, and you're lucky because I believe they still make replacements sending units for your year car (not just the float). I've also seen sending units on eBay as well.
    All you have to do is drain the gas, then there is a slip collar on the drivers side of the tank that you have to tap with a rubber hammer/screwdriver to loosen up. Once that is off, the sending unit will come right out. You also might want to get a new gasket, just in case the old one is shot....
  9. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    that sounds straight forward. so the tank has to come off or can I do this with the tank on?
  10. A_Bartle
    Michigan's Thumb
    Nope, no reason to drop the tank. The sending unit is on the lower "side" of the tank, and it'll actually be a fairly quick project. Takes longer to drain the tank (I used a syphon hose) than to replace the sending unit....
  11. A_Bartle
    Michigan's Thumb
  12. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    great, thanks for all the info. I'm gonna get under the car and check it out.
  13. justin has a 74
    kentucky
    you are not alone.. but ive never let it get on E lol
  14. 1moregear
    1moregear Member
    mississippi
    74 and 76 maverick
    sending unit
    There is a company called tristar radiator that rebuilds units. Ithink they are in NY. State They say they can rebuild any sending unit.
  15. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    Well so I ordered the sending unit so I can have it in case I need to replace it. I'll see if there is something that I can fix myself on the one I have right now. If I don't need the new one I'll return it.
