Turbo charged 300 straight-6 in a mav!!!!!!
Discussion in 'General Maverick/Comet' started by ericglo, Oct 15, 2008.
  1. ericglo
    ericglo Member
    n/e illinios
    1972 maverick
    Thought you guys might like this!!! It's got a stock 300 out of a truck with a tubocharger and intercoller runs 11.30's!!!
  2. hacksaw415
    hacksaw415 Member
    slum bum frisco
    75 booger green mav
    nice, fatest 6 ive ever heard of in a mav. a guy out here has a 96 cobra, with a supra 6, and a BIG turbo, dont know what it does at the track.
    id bet youre faster than sum v8 mavs.
  3. 71mavkidd
    71mavkidd Member
    Kansas City, Kansas
    wow. i was actually thinking about doing that myself. I like it
  4. Mad Goon
    Mad Goon Scaring the Hondas
    Redondo Beach, California
    Whoa that's bad...
  5. timsrick
    timsrick Member
    woodville,ont.canada
    1977 maverick,77 comet
    :bowdown:wicked
  6. white trash
    white trash Member
    Leland, NC
    1969 1/2 Maverick 6cyl auto field find junker
    Looks like a really clean install on that too. I'm sure he had to do a few mods to that Holley to run boost through it. I have a few turbos laying around and may play around with that one day.
    Another way to turbo charge a carb'ed car without having to mod the carb is to completely incase the whole carb air tight and boost it inside the "carb box". Then the pressure in the carb and all around it is the same. You don't have to worry about brass floats collapsing or seals in the carb blowing out. I have never done it, but it has been done. In theory it will work.
    I wonder how much boost that 300 will take. I bet it will take a good amount before it blows to pieces. I also bet it's better to run a smaller fast spooling turbo for lower end power.
  7. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    No tower braces... not good.
  8. 302mav76
    302mav76 Isaac Serna
    Monterrey, Nuevo Leon, Mexico
    '76 Maverick
    a monte carlo bar like the one chirt has on his Mav could help there.
  9. Grabber5.0
    Grabber5.0 Gear-head wannabe
    Kansas City, MO
    71 Grabber
    That is really cool!!! :clap: Amazing what you can do with forced induction. :D
    Not trying to start something, but honestly I'm kinda tired of hearing people say that. I ran my 77 for almost 20 years without tower braces (were gone when I got it), and never had any issues. I did finally get a pair, but I hated the brace made to go around the power brake booster, so I never installed them. I did set them in place, and the shock towers had moved in maybe 1/4" in all those years. I have braces on my Grabber, but only because it has manual brakes and the regular braces fit.
  10. CornedBeef4.6L
    CornedBeef4.6L no longer here
    no longer here
    I always wanted to do that!!!
  11. PaulS
    It really depends on the loads you place on the front end. The engine helps hold the towers apart but the braces do a better job of it. Let's face it - they are probably not going to collapse but they can flex enough to mess with suspension geometry and engine clearance with V-8s. You can always use hydraulics to put it right and then install the braces, so if you want to run without them it is really no big deal.
  12. MNTony
    MNTony aka Godzirra
    Surprise, AZ
    Excellent job Eric! I can see that you used top dollar parts. What did you end up using for a fuel pump? I see the Aeromotive regulator, is it the A1000 pump?
  13. Jamie Miles
    Alto, GA
    I've had a few
    That fits in there a lot better then I thought it would. Very cool!
    As for the braces, bottom line for me, if Ford thought they were needed, my car is going to have them. With a car like the Maverick, I'm sure they wouldn't have wasted the time and money on them if they didn't think they were absolutely needed.
  14. 71gold
  15. Jamie Miles
    Alto, GA
    I've had a few
    Different model, not different make. It's still a Ford engine. Lets face it, these cars were meant to be cheap. If the shock tower braces weren't really needed, then they wouldn't have bothered with them from the factory IMO..
