Replacing ball joints, need guidance
Discussion in 'Technical' started by mrmalina99, Jan 10, 2013.
  1. mrmalina99
    mrmalina99 Member
    Belfair, WA
    1973 Maverick
    I am currently planning to replace all 4 ball joints/sway bar bushings/end links. Is there anything else that I should address while I am in there (problem areas/other bushings)? From reading the forums it sounds like I can remove ball joints without messing with the spring? Want to confirm before I injure myself.
  2. 71gold
    the lower control arms are sold as an assy. I don't know if you can buy the ball joint separate...
    to rebuild the front end and replace the upper control arm bushings/shafts you will have to remove the springs.
  3. mrmalina99
    mrmalina99 Member
    Belfair, WA
    1973 Maverick
    I am replacing the lower control arms, I should have specified.
  4. predfan2001
    Do the strut arm bushings and sway bar bushings too. Take a look at the spring seats also. Use quality parts and you won't have to worry about the frt end for a loooong time.
  5. John Holden
    John Holden Member
    NJ
    The lower arms and upper ball joints can be replaced without messing with the springs. If you want to do it right though you should also replace the upper a-arm pivots and the spring perches, both of which require removal of the spring. And as mentioned, the strut rod bushings and sway bar bushings and end links. While you're doing the uppers, the shocks also must be removed so you may as well get new ones if yours are old.
    Miguel Arzola likes this.
  6. rthomas771
    Only have to remove the shock to get the UCA out. Spring can stay
  7. John Holden
    John Holden Member
    NJ
    Technically that depends on what kind of spring compressor you have. Either way you must compress the spring in order to get the UCA out.
  8. Tannersg1
    Tannersg1 Member
    Classified
    Let me know if you need any assistance or tools!
  9. mrmalina99
    mrmalina99 Member
    Belfair, WA
    1973 Maverick
    Do you have the spring compressor? I am trying to read the forums right now to make sense of the upper control arm bushings.
  10. 71gold
    use...rubber...strut arm bushings...:yup:
  11. Tannersg1
    Tannersg1 Member
    Classified
    I knew you would ask for something i don't own. You can rent them from advance or autozone. Are you going with Moog parts? I would!
  12. mrmalina99
    mrmalina99 Member
    Belfair, WA
    1973 Maverick
    Most of what I have been finding is like this, is this what you are talking about: http://shop.advanceautoparts.com/we...g_20517469-p?navigationPath=L1*14921|L2*15012
    If I get these I would have to replace the control arm shaft with a aftermarket one?
    Lol, I have a good tool collection but am lacking on some of the specialty tools.
  13. baddad457
    If you're going to do it, replace the upper A arms too. It's far easier to replace the whole assembly than to fight changing 40 year old ball joints on old A arms. New A arms come already assembled with the ball joints. Steer clear of rubber upper A arm pivots. Get the steel ones with the grease fittings.
  14. 71gold
    this is the one I rented...:thumbs2:
  15. rthomas771
    I rented one just like it back in the mid 90's when it cost $25 to rent. I decided to keep it for myself. I bet I've used it more than 20 times in the past 5 years.
