front speakers
Discussion in 'Audio' started by tommyboy, Feb 1, 2008.
  1. tommyboy
    tommyboy 77 mav
    parkersburg west virginia
    1977 maverick
    Hey guys/ladies can anyone tell me where i can find some slim design speakers that will fit in my kick plate on my 77 mav, i found a web site on here before but i lost it, thanks tommyboy):)
  2. gdemopesq
    gdemopesq MOTOR CITY MAV
    Michigan
    72 Maverick 302
  3. ramblinmustang
    ramblinmustang Member
    St George, Utah
    75 Grabber....20k original miles
    Glad you started this thread. I have a 75 Mav and want to put some better speakers in the kick panels. I don't want to do any cutting. Any good speakers that will work?
  4. Craig Selvey
    I think you will be happier with the indash install of a dual voice coil speaker. Do a search for the thread I wrote about it.
  5. gdemopesq
    Michigan
    72 Maverick 302
    The opening behind the kick panel is tiny. I dont think you will get a good speaker to fit in there without some cutting. The speakers I put in are 6.5" and only needed to trim an inch or so.
  6. Chinguschild
    Chinguschild The Bass Player
    Orcutt, Ca
    71 Grabber
    if any will fit it will be the shallow infinity speakers.
    crutchfield.com
    Check them out there then shop it around at best buy or your local audio shop for a better price. crutchfield is overpriced a lot.
  7. Jamie Miles
    Alto, GA
    I've had a few
    I have Sony Xplode speakers in the front kick panels of my '72, and my main complaint having them there is I have to crank the fade to the front more then the rear in order to balance out the sound. Otherwise, the rear speakers drown out the front ones, and it sounds like all the sound is coming from the back speakers, can hardly even hear the fronts. That creates another problem, in that if you crank the volume up some, the front speakers are working much harder then the rears, so the sound starts to get distorted pretty easily.
  8. 19BlacK77
    19BlacK77 Member
    I agree with Jamie on having to put the fader to the front some but I only have to do it 1-2 notches and it balances out fine. I have a pioneer HU with 6 1/2" 180w 3-way speakers up front and 6x9 AC Delco speakers in the rear out of a 99 olds alero. I know they are GM but they are great for factory speakers and they are CHEAP!
  9. Chinguschild
    Orcutt, Ca
    71 Grabber
    You want to match your speakers as closely as possible to avoid this. Higher wattage speakers will be less effecient that low wattage speakers.
    If you put low wattage speakers in the rear deck and competition speakers or just a nice high power handling set the others will drown you out.
    Also the deflection of the rear window seams to bounce the sound up front radically. I built custom kick panels and my speakers air aimed so that i dont have the problem but i dont think you should if you have a matched set of speakers.
  10. d_chavez
    d_chavez Member
    Las Cruces, NM
    70 Maverick 302 C4
    i put a 6.5 in sony xplode speaker in the dash where the original speaker was its was pretty easy just had to make 2 small brackets i had some speakers in the kick panels but i cut the panels up to put em in ....now i need to get new kick panels it sounds pretty good in the dash i guess it just depends how loud you want your system im doing good with 2 6X9s and that 6.5
  11. Jamie Miles
    Alto, GA
    I've had a few
    My speakers are a matched set of Sony Xplodes. It seems to have more to do with acoustics then the speakers themselves. The rear speakers are aiming up at the window which acts like a bullhorn, while the fronts are aiming at the transmission tunnel, which does no good. In my '73, I'm going to either put the front speakers in the top of the dash or behind the grilles on either side of the package tray under the dash. My '80 Capri RS has the speakers in the top of the dash aiming at the windshield, and it sounds very good and balanced. I listen to mostly rock music like Metallica (ironically, "wherever I may roam" by Metallica is coming on the radio as I typed that), so I don't really care about a big booming system, I just want it to sound tight and balanced.
  12. Chinguschild
    Orcutt, Ca
    71 Grabber
    im a musician so im freakin picky. haha (y)
  13. Moglie
    Moglie Member
    North Carolina
    Kick panel speakers
    Do you have any pics of the custom kick panels you built? I would like to see how you got around the parking brake, and the headlamp dimmer!
  14. CaptainComet
    Another tip about front speakers ... the metal behind the kick panels was changed to accommodate speakers in the later Mavs/Comets. I want to say that this happened in 73 or 74 and there are factory kick panels that have a speaker grille built in, so it all looks factory. I think they take 5 1/4 inch speakers.
    I have had a 71 and my current 72 Comet and both of them took some metal surgery to make room for speaker magnets. In both cases, I surface-mounted speakers to the kick panel. My 72 has 4 inch Infinitys.
    I am probably going to add a plate with two more front speakers in-dash, too.
    I am running two 6x9s under the rear metal deck ( the factory holes aren't 6x9 ! ... grrrrr) and a modest amp to them.I took the package tray, created openings for the speakers and then covered the entire package tray with speaker cloth. I left some "ribs" in the speaker opening so that the cloth would not sag. It looks pretty trick.
  15. Craig Selvey
    Every Maverick I have seen has had factory 6 x 9 rear speaker holes.
