Mobile Tags Register Gallery
Go Back   Ford Maverick / Mercury Comet Forums > Maverick/Comet Forums > Technical
Notices
Reply
Thread Tools Display Modes
Old 2004-11-01, 18:12   #1
Jap901
Member
Jap901's Avatar
Vehicle(s): 70 mav 2 door
Question Injectors
Hello I got these injectors some time go and was told they were red 19# injectors off the newer 5.0 mustangs but i look up the part# on them and found out they are 22# injectors D9D http://www.fiveomotorsport.com/Injec...DS.asp#bosch19 what I was woundering is will these work of with my MAF the is set up for 19# injectors?
Jap901 is offline   Reply With Quote
Sponsored Links
Old 2004-11-01, 18:50   #2
Bluegrass
Jr. mbr. not really,
Vehicle(s): 73 Comet GT, EFI, C4, Posi
They won't work correctly because the injector flow rating must match the Mass Air "transfer function" or output versus airflow, said another way.
You could put them in but expect the engine to run a bit rich. Backing down the fuel pressure might also be appropiate in that case, so they flow more nearly that of the 19 lb units.
On a Speed Density system you could get away with it because the MAP sensor does the load signaling in the absence of an air meter and the computer will reset it's tables to account for them up to +/- 12% either way.
__________________
73 Comet GT, EFI
90 Lincoln Mark VII supercharged.
02 F150 Super Crew
Bluegrass is offline   Reply With Quote
Old 2004-11-01, 19:49   #3
Jap901
Member
Jap901's Avatar
If i got a maf sinser off a cobra for 24# injectors I gyess the engine would run lean then or could i just pump up the fuel presser? note i have AL9 computer from a 89 mustang with a superchip installed and the chip makes it run richer and the chip says to remove the cats
Old 2004-11-01, 23:28   #4
Bluegrass
Your getting into too many unknowns.
The a9l eec is calibrated for 19 injectors unless the chip change this.
You will have to try it and see what happenes.
__________________
73 Comet GT, EFI
02 F150 Super Crew
Reply
Interested in this thread?
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
24 ibs injectors anyone? maverickkidd Maverick/Comet Cars/Parts For Sale 0 2006-11-20 22:04
Will, another EFI tidbit when using non HO EFIMAV Technical 11 2002-12-26 08:39
Powered by: vBulletin
