Tire Size
Discussion in 'Technical' started by TONY, Mar 15, 2005.
  1. TONY
    TONY Member
    el paso tx
    72 maverick
    heay guys what r the fattest thickest tires i can fit on the back of my 72 mav with a stock rear end i think
  2. Andysutt
    Andysutt '72 Comet GT
    Conway Arkansas
    1972 Comet GT
    That all depends on the height of your tire, and the backspacing on your wheel
    I run 28x11's on my car (the 11'' is just the flat part of the tire, not the "sidewall curve")
    But they stick out the side of the car about an inch due to the backspacing of the wheel.
    Im going to experiment but the widest i've seen is 28x10.5 that didn't stick out the side and that was w/ some centerline wheels that mavman had.
    I'll ask him the backspacing when i talk to him again
  3. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    Not only do you need to think of b/s, width, and/or offset... but you must think of rim diameter too.
    I have seen 275/60/15s on Mavs, but it is hard to make them look good IMO, and the backspace needs to be 'just so' or you have scrub problems.
    255/60/15s are about the largest that look good IMO. You still need the right b/s to get them in there.
    I can't stand cars with the rubber sticking out of the wheel wells. Some folks like it though, you see it all the time.
    Dave
  4. courier11sec
    courier11sec Member
    Tucson, AZ
    my 275/60/15s were tucked inside the fenders, but I had to get creative on the inside of the wheelwells. that was on cragars with 4 1/4 backspacing I've found the best is 3 3/4 for that tire size, but the rear of my car is a bit higher than stock.
  5. Andysutt
    Conway Arkansas
    1972 Comet GT
    I agree on them sticking out the sides
    Mines not noticable from the side really, but from the front you can tell a bit
    But considering the slicks/rims where free Im running them. And its just a drag car anyways
  6. NICK DOMINICK
    Burke, Virginia
  7. Scotty P
    Scotty P Member
    santa rosa, ca
    I run the same as Ray and mine are tucked. 4 7/8bs 15 x 8.5 centerline.
    Ray, picked up the edlebrock rpm heads on ebay today for less than a grand.. Getting excited!
  8. courier11sec
    courier11sec Member
    Tucson, AZ
    Swwweeet Scotty!
    One day we've got to get these twin hot rods of ours together.
    I'm planning on going to 275/50r15 drag radials this year to match my 26 x 11.5 slicks.
    My goal this year is not necissarily to go faster, but to get the front wheels off the ground. I'm predicting a broken rear end this season.
  9. Scotty P
    Scotty P Member
    santa rosa, ca
    LOL! Already did that! Now I am looking to twist an axle with the powertrax unit in! Thinking of aftermarket axles with studs this year. Opps, did we highjack this thread?
  10. courier11sec
    courier11sec Member
    Tucson, AZ
    hehehe. Sorry fellas!
  11. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    The only thing that looks better is you tearing up the air guitar singing "strangle hold" :bouncy:
  12. MaverickRunner
    MaverickRunner Member
    North Port Florida
    73 Maverick 302
    275's fit fine without sticking out or rubbin
    sorry only picture I had
