Mobile Tags Register Gallery
Go Back   Ford Maverick / Mercury Comet Forums > Maverick/Comet Forums > Technical
Notices
Reply
Thread Tools Display Modes
Old 2005-03-16, 10:00   #1
Jap901
Member
Jap901's Avatar
Vehicle(s): 70 mav 2 door
Question 302 Distributor?
I have a 89 302 that was not an HO but was SD & it had a roller cam. I am going to use a carb set up with it not the efi and was woundering what distributor do i need to use? is there a diff in lenght from the older to newer distributor?
Thanks
Jim
Jap901 is offline   Reply With Quote
Sponsored Links
Old 2005-03-16, 11:30   #2
Grabber5.0
Gear-head wannabe
Grabber5.0's Avatar
Vehicle(s): 71 Grabber
Images: 21
I just replaced the gear with a bronze gear and used my old dist from the 302 in my car (for now... will buy a new setup eventually)
__________________
Matt Williams
'71 Grabber 5.0
Grabber5.0 is offline   Reply With Quote
Old 2005-03-17, 11:46   #3
tim keck
truckdrivintrailertrash
tim keck's Avatar
Vehicle(s): '72 Comet, '75 Maverick, '85 F150 4x4 ,'93 F150,'75 F100,'77 Jeep Wagoneer,'91 Dodge D250 Cummins,'90 F150 xtra cab 4x4, '93 F150 4x4
Images: 1
Any carbed 302 dist. will work,just put the bronze gear on it.Only factory one that will drop in w/no mods is the '85 GT 5spd dist.(most of the auto '85's were TBI)it already has the bronze gear.
__________________
"I like 14 dollars having 27 cents"- Roger Miller
tim keck is offline   Reply With Quote
Old 2005-03-17, 18:43   #4
Jap901
Member
Jap901's Avatar
The cam that i am now using is A Erson roller cam and it cam with a paper that says this camshaft is compatible with stock type steel distributor gears.
Duration 294 @050 226
304 @050 234
Lift .544
.544
lob center is 110+4
Old 2005-03-17, 23:16   #5
460Comet
466 gallons/mile
460Comet's Avatar
Vehicle(s): 1977 2 dr. 466 BBFord, C6 auto, 8 inch rear.
stock dist gears on non roller cam engines are cast iron, not steel. It'll probably shatter on a steel roller cam, so just be aware.
__________________
1977 Comet
466 cid, C6, 8" 4.62:1
Stock front suspension.
See it at www.casey.freehosting.net
or
www.flatbrokeracing.freeservers.com
or
www.homestead.com/comet466/homepage.html
460Comet is offline   Reply With Quote
Old 2005-03-18, 08:53   #6
Thack
vision advicator
Thack's Avatar
Vehicle(s): 71 2 Dr Maverick, 70 Mustang Sportsroof, 77 F100 4x4, 72 maverick grabber wifes
For steel roller cam shafts, Ford racing catalog recomends a steel gear (PN M-12390-b) for the distibutor on street cars over Bronze gears. Bronze gears have a faster wear rate and on race engines they are removed and inspected more often than steet cars. The Ford gear comes with very good instructions on placement also.
Thack is offline   Reply With Quote
Old 2005-03-18, 18:33   #7
stmanser
Looking for a Maverick
stmanser's Avatar
Images: 10
i had a single point distibutor on my 302 and i had to change the point about every 3 months and had to gap it about once a month.....
i changed to the MSD complete ignition system and now i dont have to change anyhting....
the distributor i have is the MSD Pro Billet Distributor.....and has the wide cap ...cost me about 250 i think
stmanser is offline   Reply With Quote
Old 2005-03-18, 22:22   #8
CornedBeef4.6L
Voted off the Island
CornedBeef4.6L's Avatar
Images: 3
As mentioned you can use an 85 ho dizzy from a mustang.(I believe they cost about 95.00 reman from parts houses) or order this one from MSD
Ford 302/289 with Steel Gear for Hydraulic Rollers PN 8598*
This is mechanical advance only. Large cap. It does have the steel gear already pressed on. Trust me when I say it is a pain to get it right. They offered this part after I totally ruined my dizzy. Take into count I have rebuilt at least 40 dizzies and pressed many gears and bearings but this was the worst I tell you. MSD did take care of me though. Great customer service. Gave me a new dizzy and pressed the gear on at no charge.
*Not legal for sale or use on pollution controlled vehicles.
CornedBeef4.6L is offline   Reply With Quote
Old 2005-04-02, 17:43   #9
jim_barbier
Member
Vehicle(s): 1975
yes def. use a steel gear on your app. or bronze a cast will wear out both gears, dist. fist luckily and there are two different distributtors in length from the cam gear down to the oil pump shaft (or rod) make sure yours is the same length that you pull to whaT YOU REPLACE. the only other diff i know of is the diameter of the shaft where it goes through the timing chain cover and make sure they are the same because if you put in one with a smaller diameter it will go in but cause problems at the gear and the oil pump after so many miles even if it works from the get go
jim_barbier is offline   Reply With Quote
Reply
Interested in this thread?
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
1988 t-bird 302?? 754dr. General Maverick/Comet 5 2009-12-31 20:34
Bogus Boss 302 Clevor Parts and grabber stripe kit EFIMAV Maverick/Comet Cars/Parts For Sale 14 2008-03-31 20:27
will a 302 boss crank go into a 302 block obmav Technical 14 2007-06-14 12:17
Getting Distributor to seat all the way Halebopp Technical 26 2005-06-03 12:54
Powered by: vBulletin
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
