Intersting AODE / 4R70W Transmission and stalls info
Discussion in 'Technical' started by Jap901, Apr 11, 2005.
  1. Jap901
    Jap901 Member
    Scotts Hill Tn
    71 mav 2 door
    How much power can a stock AODE/4R70W transmission take?
    The AODE/4R70W in stock form can typically handle about 25 to 50 horsepower above stock power levels. Before planning many engine mods to an AODE/4R70W equipped vehicle, you should install our AODE Valve Body Kit. Installation of the Valve Body kit will allow 1997 and earlier AODE/4R70W transmissions to perform reliably in a 350 to 375 horspower application. 1998 and later 4R70Ws can handle up to 500 horsepower with just the addition of the Valve Body kit.
    A stock torque converter in an AOD equipped Mustang will produce a stall speed of about 1800RPM, while the stock 5.0L H.O
    Stock 5.0L Mustang AOD-E torque converters stall at about 2400 RPM, and will provide significant improvements over an AOD converter
    http://www.baumannengineering.com/index.htm
  2. lbr
    lbr Member
    Fresno, CA
    11 second '72 Comet, 302, 4 spd
    Thanks for AOD info. Cool Avatar!
    Rocky
