C4 - Column to Floor shift swap ...
Discussion in 'Technical' started by dmhines, Jul 2, 2005.
  1. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    From what I understand the bracket on the tranny where the shift rod connects to needs to be flipped since the floor shifter pushes and the column shifter pulls. Anybody have a picture of this part flipped both ways and what is the easiest way to do it?
    Thanks ...
  2. Jason M
    Jason M Hibernatin for the Winter
    Wingham, Ontario
    1976 Ford Maverick
    wish i could help dan, but I used a cable activated shifter that included a bracket to bolt onto the c-4 linkage
  3. Pegasus
    Pegasus Powder Coating Nut
    Channelview, Texas
    '76 Maverick 2 door 302 V8
    Dan,
    I'm also using a cable-activated B&M Starshifter. Was very easy to hook up.
  4. victor paz
    victor paz PAZ
    California
    77 MAVERICK, 73 MAVERICK, 70 MAVERICK, HAD A FEW PARTS CARS
    aod
    has any one used a b&m with an aod?
  5. dmhines
    Cumming, GA
  6. T.L.
    T.L. Banned
    Southern Colorado
    '73 Maverick 2-door, V-8
    If you're using a factory floor-shifter, You have to swap the shift bracket with the correct one. I doubt you can simply "flip" the one that's already on there...
  7. grbmaverickmo
    Aquashicola, PA
    When I did the swap the valve body had to be pulled out in order to pull the lever out. There is A nut on the lever inside that has to come off. IF you want a pic of the factory bracket I will try and get you one.
  8. dmhines
    Cumming, GA
    So did you use the same one that was used for the column shift and just flip it or did you swap it with a different lever?
  9. grbmaverickmo
    Aquashicola, PA
    Sorry forgot to say I used a different lever.
  10. dmhines
    Cumming, GA
    Yeah ... beginning to see that the column lever is quite a bit different ... looks like flipping it 180 would not help since it appears that it should really go only about 90. I'm thinking maybe a Mustang one would work, an original Maverick lever or possibly an aftermarket clamp on style that B&M or TCI sells ...
  11. T.L.
    T.L. Banned
    Southern Colorado
    I don't see why a Mustang lever would not work, since they had C-4s and used the same design floor-shifters...
  12. Mavaholic
    Somewhere I have a floor shift arm that I took out of a Granada. I'll try to find it today and get a pic of it.
  13. Earl Branham
    Lugoff, SC
    Dan; when I changed mine over, I used a Mustang ('67) shifter, and I got the shifter arm and rod from the same car. The arm for the floor shift has a flat on it that the column shifters don't have. I may have one, and I will let you know if I can find it.
  14. dmhines
    Cumming, GA
    Thanks!
  15. Grabber5.0
    Grabber5.0 Gear-head wannabe
    Kansas City, MO
    71 Grabber
    My floor-shift arm is from a 82 or so Mustang. Sticks out a bit far so I had to clearance the tunnel a hair for the other end of the shift lever, but it works. It was only hitting when in Park and Reverse, all other gears were fine.
