C4 - Column to Floor shift swap ...
Discussion in 'Technical' started by dmhines, Jul 2, 2005.
  1. Earl Branham
    Lugoff, SC
    Dan; looked, and the part is not here. Must have lost it or let it go a few years ago. Sorry. I will ask a friend that is in the trans business, see if he can locate one.
  2. fan2488
    fan2488 Member
    spring,TX
    1969.5 maverick, 1972 grabber
    dan, here is the piece i made for mine.(sorry for the bad pictures) it slips over the shaft with two pieces extending over the trans lever. if these don't make any sense to you, i will take it off and get a better picture.was in a hurry today. i will drew a sketch to try and clearify the photos.works great on my car.
  3. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    I see you welded to the original .... Thanks .... Just curious .... what gear is the tranny in when you have the lever at 12:00 (or is it 1:00 ) like you show in your picture? I assume that is park?
  4. fan2488
    fan2488 Member
    spring,TX
    in the picture the trans is in park,and shifter is in park. all gears line up with shifter letters still adjustable under shifter. that is like a big washer, so it will slid on and off. not welded to trans. sorry about the explaination, i have a hard time trying to tell how i did something.did you get my pm i sent you?
  5. dmhines
    Cumming, GA
    Just replied to your PM ... Thanks ...
  6. MapleMav
    MapleMav Member
    Moose Jaw, SK Canada
    '72 Sprint
    Dan, here's a pic of the lever I got from a '75 Monarch. Not sure if you're planning to use a factory neutral safety switch mounted on the tranny, but if so, this is what you need since it has the "dog" on it that turns the switch.
  7. dmhines
    Cumming, GA
    That Monarch one looks just like a Maverick lever ... Thanks ..
  8. T.L.
    T.L. Banned
    Southern Colorado
    '73 Maverick 2-door, V-8
    What about the back-up lights? Mine never worked after I converted to a floor-shifter, so is the back-up light switch integral with the neutral safety switch, or is it a separate switch?...
  9. ronr11
    ronr11 Member
    hartsville sc
    71 maverick
    backup lites
    they are also part of the neutral switch it's a black wire with a pink tracer
    put it in reverse and test with a lite at the b/p wire
  10. T.L.
    T.L. Banned
    Southern Colorado
    Thanks, I'll check it out. I may need a new switch, but the neutral safety function works fine...
  11. dmhines
    Cumming, GA
    Look at the work of art Ed made me for my floor shift conversion .....
  12. Jamie Miles
    Alto, GA
    I've had a few
    Off topic, but after seein' those pics, I don't feel nearly as bad about how my trans looks now. :D
  13. fan2488
    fan2488 Member
    spring,TX
    i know jamie, i have not done anything to my trans or engine yet
  14. Hawkco
    Hawkco Genuine Car Nut
    Rex, Georgia (GA)
    77 Maverick
    B&M makes a cable conversion for Mustangs to be able to install a C-4. I bet that would work. It comes with cable, linkage piece for the tranny, etc.
  15. MapleMav
    MapleMav Member
    '72 Sprint
    I resemble that remark. :16suspect But hey, look how clean and shiny the pan is though! :yup:
