Help with mounting electric fan between radiator and old fan pulley
Discussion in 'Technical' started by scooper77515, Jul 18, 2005.
  1. scooper77515
    IF you have been following a couple other threads of mine, you recognize that I bought a fan from a Taurus, I think, mounted it in front of the radiator, but when wired backwards to push rather than pull, it sounded like an air boat from the swamps of Florida.
    So, now that it is wired correctly, I have to figure out how to get it between the radiator and the water pump pulley.
    It has a 2-3 inch deep shroud, that may need to be cut (maybe to a shallow square just bigger than the fan, then rubber gasket between it and radiator?). I was going to get input before cutting into this fine ($25) piece of engineering feat.
    Any suggestions before I cut?
  2. scooper77515
    Lots of lookers, no suggestions :huh:
    A couple days of this and I will cut the shroud and MAKE the thing fit.
    I would love to see some pics of others' cars with electric fans.
  3. scooper77515
    Nevermind. Somewhere in the midst of taking the fan back out and trying to fit it inside, I banged the electric motor, or something. Now it won't run. All wires are good, and connections, but the motor won't turn anymore.
    Back to the junkyard with another 25-dollar bill... :huh:
    This time, I will find something that is still on a car, and either find a pusher, or a puller with a narrower design. Any suggestions on which car(s) might have something that fits with minimal modifications?
  4. Maxx Levell
    Maxx Levell Member
    Henderson, KY
    I just ran into this the other day. I went to mount the fan/shroud combo, and it wouldn't fit in between the water pump snout. I "modified" the water pump by taking a cut-off wheel and trimming the stud on the front of the water pump even with the pulley. I now have plenty of clearance.
    HTH
    Later,
  5. scooper77515
    My problem was (WAS) that the fan/shroud combo was nearly 6" deep, I only had about 4" before I hit the water pump.
    I am looking for another thinner fan now.
    And it worked so well for a couple days... :huh:
  6. Earl Branham
    Lugoff, SC
    Scooper; I had that problem when I tried to install an electric fan in my car. I had about 1/4" clearance to the pulley. I put it in and had no problem with hitting the fan motor, but it just did not do the job. I went to a stock 7 blade fan and a good shroud. Problem solved. Good luck. BTW, my computer at home is on the fritz. I will mail you the pics of the seat rails when I get it fixed....hopefully tomorrow. I have not forgotton you!!!!!
  7. scooper77515
    Thanks Earl,
    See you at Owensboro? If your car will be there, I can take my own pictures (y)
  8. ronr11
    ronr11 Member
    hartsville sc
    71 maverick
    i found one off a honda( much thinner)and i while i was at the yard i got a serp pully setup off a crown vic along with the alt and did away with the metal fan and spacer
  9. scooper77515
    My wife said just yesterday "wasnt the one on our Honda Accord really thin?"
    She is so smart.
    I know where three of them are in the yard as we speak.
    And the serp...? Hmmmmm..... :rolleyes:
  10. Earl Branham
    Lugoff, SC
    Scooper; sorry, will not be at Owensboro. Boss insists that I work! Can you imagine that:cry: . I'll get you some good pics soon. Sorry for the delay.
    Earl
  11. scooper77515
    Sorry we won't get to meet you in person.
    We will be stopping for just one afternoon, anyway, on our way through to a family reunion in PA.
  12. Earl Branham
    Lugoff, SC
    Scooper; enjoy the Roundup, and be very carefull on your trip.
  13. Grabber5.0
    Grabber5.0 Gear-head wannabe
    Kansas City, MO
    71 Grabber
    Work shmerk, I'm tired of work. Don't listen to your boss, your job will be there when you get back, I promise. :evilsmile
  14. scooper77515
    Your job will definitely be there when you get back...But someone else will be doing it :mad:
  15. 77mav302
    77mav302 Member
    Spokane WA.
    77mav302/2dr, 70mav 2dr
    You could get on from a newer Taurus/Sable that is a 2-speed with three wires coming out of it and it is thinner. when I did my son's, I put the fan off-center a little towards the driver's side and it (the motor) fit in between pulleys and belts. Older style like the one you had.
