strange question
Discussion in 'Technical' started by 72maverick555, Nov 4, 2005.
  1. 72maverick555
    72maverick555 New Member
    WICHITA KANSAS
    1972 FORD MAVERICK
    Actualy have 2 questions 1st the car my 72 has had a problem keeping ME warm the heat from the car is verry poor i have replaced the heater core andflushed the lines and cooling system am i missing something or is this just a maverick problem we live with?? 2nd how do i up date my profile and add things such as pictures??
    Scott :huh:
  2. Stefan
    Montreal, QC
    Click on the "User CP" at the top right corner of the forum and then click on "Edit Profile" http://mmb.maverick.to/profile.php?do=editprofile If you want to add a signature, click on "Edit Signature" from the User CP http://mmb.maverick.to/profile.php?do=editprofile
    I you do not have a place to host a picture for your signature, e-mail (maverick@maverick.to) it to me and I will host it for you.
    You can upload pictures to the forum by clicking on "Manage Attachments" button (Scroll down to the bottom of the page on when typing your message). Once you make 10 posts or more, you can upload photos to the photo gallery.
  3. scooper77515
    Is your car running at running temperature, 180 or so? After it has warmed up, turn your heater on full blast...air should be coming out of the vents pretty fast. Now reach under the hood and grab one of the heater hoses that go into the firewall, and it should be pretty warm, but not too hot to touch. Grab the other as well, it should be pretty warm too.
    If they are both warm you likely have an issue inside the heater box, either the core or the flapper door. If they are not warm, the your problem lies more with the heater hoses, or water flowing through the thermostat housing/intake manifold prior to getting to the heater hoses. If one is warm and the other is not, definitely a blockage in your heater core.
    Start with those and report back. Someone here will help you narrow your problem down.
  4. 71gold
    make sure your "temp" cable is hooked up. there is an eye on the end of the cable that pops off if it doesn't have the clip on it. this is what opens the door to let the heat into the car...frank...:bouncy:
    p.s. it might also be a geographic thing :yup: .
  5. Mavaholic
    Does the air blow out of the floor vents? Is your car factory air? A new heater core dosent necessarilary mean its a good one.
  6. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    Do you have a temp gauge on your car?
    I was wondering if someone put a low temp thermostat in there sometime in the past.
    Good in the summer, but not good in the winter when you want heat...
    There are many good ideas floating in this thread, if they check out, look into a higher temp thermostat. Yours may be stuck open as well. This makes for a painfully slow warm up and low temps at all times.
    Dave
  7. hotrod-daddy
    hotrod-daddy Member
    Rock Springs,Wyoming
    a 1971 Grabber with a 302/351
    ...heat concern....
    I think a person gets used to these new cars with their superb air flow,and when they get in a earlier built car (not just a Maverick).....they see a huge difference. Just my input/outlook....:cool: Hotrod-Daddy
  8. Mavaholic
    I never had an issue with mine. It was always nice & toasty inside when needed.
