Another front disc brake alternative...
Discussion in 'Parts Interchange' started by Craig Selvey, Nov 25, 2005.
  1. Craig Selvey
    Here is an auction selling special brackets for mounting disc brakes on the front of a maverick without changing the drum brake spindles. It uses:
    * 1985-89 Buick Park Avenue front rotors (4-1/2" bolt circle)
    * 1983-97 Chevrolet S10 4WD calipers and pads
    * 1979-85 Cadillac Eldorado front hoses
    The ebay seller's ID is: scarebird
    Check out the auction here:
    http://cgi.ebay.com/ebaymotors/1964...ewItemQQcategoryZ33564QQitemZ8017056899QQrdZ1
    Looks interesting.
  2. Acornridgeman
    Wisconsin
    GM mutt parts on a Ford? :tsk:
    Seriously - that makes my "learned something new today" list.
    Thanks Craig!
  3. Stefan
    Montreal, QC
    I read an article where a racing maverick used corvette brakes.
  4. bmcdaniel
    Jim Allen has some sort of GM disc setup on his Mav.
  5. Mavericknutt
    Mavericknutt member
    BoisdArc mo.
    1971 maverick 2dr m2 front end coil over ladder bar rear suspension 472 ci. C-6 tranny
    Jim Allens car is like mine with a M2, for them you can buy a bolt on bracket that uses the GM metric caliper and the mav/granada rotor and bearings/seals.
  6. Mercurycruizers
    Venetia, PA
    He's local. I'll have to check him out...
  7. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    Go to Stangnet and do a search on this swap.
    It will be many times discussed in the classic forum.
    Probably 2/3s of the folks that have used this swap on their Stangs complain.
    Not about the swap itself, but the inherent poor quality of the GM calipers and rotors.
    Just thought I'd give that info and where to follow up... ;)
    Dave
  8. bmcdaniel
    That's interesting because when I talked to Jim Allen about it at Roundup he said he used the GM parts because they are better than Ford's. Personally I find that hard to believe.:D
  9. ratio411
    ratio411 Member
    Pensacola
    :huh:
    The Stangnet guys complain of stuck calipers and instant warp rotors...
    Doesn't sound good to me.
    If one or two guys complained, I wouldn't even mention it.
    However, the majority complain, and the issues are similar.
    Food for thought.
    I am not dumping on the swap myself. I think it is ingenious and I haven't done it myself to make complaints.
    Dave
  10. Mavericknutt
    Mavericknutt member
    BoisdArc mo.
    I've never had the gm calipers stick on me....on anything....as for the rotors they are not gm anyway.......and the calipers probably depend on who they were rebuilt by........and the rotors for that fact it on them it does make a difference as to where they are made as for the quality.
  11. Scarebird
    Scarebird New Member
    Bothell, WA
    71 Lemans Sport
    We recommend that you use a quality rebuilt caliper, or if equipped and capable, do it yourself. Sticking issues are the direct result of "bargain" rebuilders, not manufacturer. We chose GM calipers due to cost, pad selection, availibility and ease of mounting. We have heard no issues ourselves about this from our customers. Most Ford calipers require a machined slider, ala Granada/late Maverick.
    We are in the final stages of a setup that will use Mustang/Mav/Comet unicast rotors. They run $37 dollars at NAPA and have the correct small center hub. These brackets were a nightmare to get to fit behind the axle centerline, but it looks like a winner.
  12. Craig Selvey
    Thanks for checking in here Scarebird. I know I look forward to what you are doing with the unicast rotors. With factory disc brake set-ups becoming scarce....it is nice to see a low cost alternative.
  13. CornedBeef4.6L
    CornedBeef4.6L no longer here
    no longer here
    Having done thousands of brake jobs I will say that the S10 calipers do tend to stick along with many other Gm calipers. The good thing is they are fairly inexpensive. I run this same caliper on the back of my car.
  14. ratio411
    ratio411 Member
    Pensacola
    What is your primary reason for using the hub/rotor combo?
    Is it more stable, brake better, longer lasting?
    I am just curious...
    In truth, I very much like being able to swap a rotor without disturbing the hub.
    The kit that does this is a stroke of genius IMO.
    I just worry about some of the feedback I have heard on other Ford boards.
    Again, not about the product, just the lack of durable parts.
    I am no longer in need of a kit now though. I was just given a set of Fairlane spindles and picked up loaded calipers and unit rotors from eBay for a heck of a deal.
    My other Mav has a set of Granada brakes waiting for it...
    Maybe I'll try the retrofit kit on my next one. Hopefully that will be soon.
    Dave
  15. Scarebird
    Bothell, WA
    71 Lemans Sport
    Ratio,
    We went to SEMA this fall and chatted with Scott Drake. They were not interested in the hat style rotor, as it required the customer to go to a machine shop. We found this to be hindering sales, as most simply want to be able to change out parts in an afternoon and not dope around with lathes and such. As far as costs go, our setup was unbeatable. We are examining the 68-73 Ford caliper, but do not like what we see.
