Project Rim Blow Steering Wheel emblem ...
Discussion in 'Cosmetic' started by dmhines, Jul 3, 2006.
  1. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    I started another project ... creating a factory looking steering wheel emblem for my Rim Blow Steering wheel.
    I currently just stuck one of my decals over the top of the factory Mustang Emblem but I wanted something a little nicer.
    The hole in wheel pad for the emblem is exactly 2 inches. I found some PVC conduit that was 2 inch outside diameter and cut a 1/4 inch slice of it off. I filled it half-way with epoxy and layed a piece of plastic on top. Then I used some more epoxy to affix a NOS Maverick Door panel medallion directly in the center. Once it is dry I will fill it with clear resin and let it harden and if all goes well should look factory. The last step will be to paint the trim ring with metallic paint to finish it off.
    Here are the pictures of a Mustang emblem, my decal currently on the center and my work in progress. I will let the background epoxy cure overnight and then fill it with the clear resin ...
  2. ladyeclectic79
    ladyeclectic79 Veni, vidi, vici
    Hanford, CA
    A '73 and a '70 Maverick
    HEy that looks cool!! Nice idea, do they even have decals anymore like that? :)
  3. luckyirishpride
    luckyirishpride "Youngest Comet Owner"16!
    Southern California
    2x 1971 Mercury Comets Both V8s, P/S/, A/C
    Wow Dan... There must be alot going through that crazy little mind of yours!
  4. dmhines
    Cumming, GA
    I had 500 of those decals made and sold them all ....
  5. Acornridgeman
    Wisconsin
    Is that JB Weld?
  6. dmhines
    Cumming, GA
    Actually it's PC-7 ... very similar two part epoxy. I actually used it to patch all 44 side trim holes in my Yellow car ... it's been 9 months of temperature ranges between 20 degrees in the winter and well over 100 degrees while the car is sitting in the sun this summer and it's still holding with no issues.
    http://mmb.maverick.to/showthread.php?t=18966
  7. maverick75
    looks Great:bowdown:
    How much does resin cost?and can you buy it localy or do you have to order it online? I have a Stallion cap that need repairing.
    Thanks
  8. dmhines
    Cumming, GA
    I bought the resin in a hobby store ... mix the two parts then let harden.
    Here is the emblem with the resin poured .... now I just have to let harden for 72 hours ....
  9. Acornridgeman
    Wisconsin
    You can get clear resin at hobby shops.
  10. Rick Book
    Rick Book Member
    Thailand
    Missing my old '70 Maverick
    Ctrl ^D
    (y)
  11. ladyeclectic79
    Hanford, CA
    Dude.
    Niiiiiice. (y)
  12. fan2488
    fan2488 Member
    spring,TX
    1969.5 maverick, 1972 grabber
    looks good.
  13. dmhines
    Cumming, GA
    Well ... I messed it up a little. Just got home from a car show and the emblem had set up nice. The box said heat make it harden faster so I put it in my Expedition that was sitting in the sun all day with the windows closed. Guess it was too hot. A couple of bubbles of resin broke to the surface on the tip of the left steerhorn.. :slap: :mad: Oh well .. the directions say when it is 100% hard any scratches or imperfections can be filled with more resin and it will not be noticable. So i'll sand down the bubbles in a couple of days and brush some resin on to fix it. Otherwise it is looking good ...
  14. dmhines
    Cumming, GA
    I was able to clean up the bubbles ... all done ...
    Here's the original Mustang version ..
  15. ladyeclectic79
    Hanford, CA
    Where do you get decals like that? I've never seen the Comet/Mav style before this, are they available somewhere?
