AOD yes/no
Discussion in 'Technical' started by 71gold, Aug 16, 2006.
  1. 71gold
    found an AOD in a wrecked 1984 f150. carbed. 302. the guy is selling the motor and i can get the AOD with all the parts to swap it into my mav.
    would this be "the one" i need to do the swap?
    i did a search on "AODs" and the more i read the more :slap: i got.
    your thoughts please and if this is "the one" i will do a write up on the swap :yup:
    ...Terrys' H/S friend frank...:bouncy:
  2. mavman
    mavman Member
    Arkansas
    Basically, if you can get one from a truck or a V8 Mustang, you can't go wrong. They're the 'strongest' of the AOD's....
    But I would rebuild it to be safe though. Those things are notorious for burning the OD band. They are great though for fuel mileage, as compared to a C4 or C6.
    I like the T5 myself, but I'm not shelling out $500+ for a USED T5. That's what they go for around here.
  3. Mavaholic
    Everything I build from now on will have OD. With gas prices, its a must for a cruiser.
  4. Hawkco
    Hawkco Genuine Car Nut
    Rex, Georgia (GA)
    77 Maverick
    Be sure and grab all the linkage that goes from the carb to tranny. If you don't want it, I'll take it.
    Earl's Friend Terry
  5. littleredtoy
    littleredtoy Seth
    North Carolina, Triangle Area
    '74 Comet GT
    I read something about making sure it is cable operated-OD?-as opposed to the computer controlled. I read that in the Ford Restomod book. Good investment by the way.
    Seth
  6. Jamie Miles
    Alto, GA
    I've had a few
    '84 will be cable operated. I was going to go AOD in that '69.5 and did extensive reading on it and how to properly adjust the throttle cable. That is, until I found out it won't fit the smaller tunnel... I'm going with a used T5 from MPS now.
  7. Hawkco
    Rex, Georgia (GA)
    77 Maverick
    The AOD's that were behind the throttle-body injected cars were cable operated. I'm pretty sure you can use those, too.
  8. Bill in NC
    Bill in NC Member
    Mocksville NC
    74 Mav 2dr LDO, 302, C4, PS, PB, and shag carpet baby!
    So what year Mav is the small tunnel? Just 70? My C-4 is starting to act up, and I was thinking of doing an AOD or T-5 swap soon.
  9. Mavaholic
    Just 70.
  10. 71gold
    the AOD i found has a "rod" that operates it. the rod looks like the kickdown rod on a c4. from the looks it looks like it will hook up to the holly carb i have perfect.
    Lokar has a ...bracket.#SRK4000 and a cable #KD2AODHT that is to replace the rod. the rod is a ...pusher...so does anyone know how this cable can be hooked to ...push? i called Lokar and the tec. guy told me this is the brk. and cabel i needed but didn't say how to hook it up.:huh:
    my transmittion guy said we would hook up the rod and if i wanted to do the cable later we would...
    this AOD came out of an eighty year old mans truck he bought new...
    kind of like the ..."little ol' lady" car...this is the "little ol' man" truck :D .
    ...terrys' H/S friend Frank...:bouncy:
  11. 71gold
    ...and 69.5 :D
  12. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
  13. Bluegrass
    Bluegrass Jr. mbr. not really,
    Easton, Pa
    73 Comet GT, EFI, C4, Posi
    A little info on the AOD.
    The years up to about 87 have an OD accumulator that the later ones do not have.
    The 89 up Lincoln Mark 7 trans are the best ones with more clutch plates but have longer tail shaft housings by about 1".
    The internal drums are stamped steel on the later ones and more desirable.
    Go to Baunann Engineering site to learn all you need to know.
    The OD band from the AODE can be put in the AOD, going from 1-1/2 to 2" wide, plus other changes to make the trans tougher.
  14. 71gold
    now that my mav. is in the shop :bananaman :bananaman i will start a new thread to keep up with the install...AOD (yes) install...frank...:bouncy:
  15. dweesel
    dweesel Member
    Lindsay Ont. Canada
    Hoping for AOD in '70.
    Is there no way that an AOD will fit into a '70 Maverick, or will it take a few mods to make it work? Is it a rear mount problem or a possible clearance issue in the tunnel?
