AOD yes/no
Discussion in 'Technical' started by 71gold, Aug 16, 2006.
  1. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    I believe it has to do with the small trans tunnel (floorpan) used that year.
    Someone will jump in if I am wrong.
    I think you have to do some extensive mods to the floorpan to enlarge the tranny hump. Maybe even firewall too.
    On the AOD:
    I have heard it said that the early cable versions are the ones that must be used on an early swap, however they are the weakest.
    Even in a truck...
    The AODE, especially the latest available are strong, but must be computer controlled.
    The companies that build aftermarket AODs pretty much rebuild them with AODE internals, and/or totally redesigned parts.
  2. rickyracer
    rickyracer Member
    Central Nevada
    66 Stang, 68 Cougar, 72 Comet GT
    Aod
    The truck or van AOD are the best ones. Carb=rod and get all the pieces from the carb. AOD has issues fitting in the earlier Mavs. 71+ is not a problem. I put a 89 van AOD in a 72 Grabber without a problem. I made my own crossmember. Used a rod off a carbed AOD with the kickdown lever for a Ford to work the rod. Been running for 5 yrs now without a problem.
  3. Bluegrass
    Bluegrass Jr. mbr. not really,
    Easton, Pa
    73 Comet GT, EFI, C4, Posi
    The 69/70 years never had a v8.
    The car was based more on the Falcon body, so has a tighter tunnel until the later v8 was put in as an option prompting the design change.
  4. maverick5.0
    maverick5.0 Member
    Caribbean/Puerto rico
    1976 maverick,347 stroker,c-4,sm bumpers,frt air dam/73 maverick,5.0 grabbber hood,four on the floor,v8,rear spoiler,...
    I have 3 AOD's in the shed, a 92 mustang 5.0 AOD, cougar 5.0 AOD and a AOD that was given to me with a 3,500 stall converter,but don't know where it came from/veh. is their any codes to classify the trans ?????
