Mobile Tags Register Gallery
Go Back   Ford Maverick / Mercury Comet Forums > Maverick/Comet Forums > Technical
Notices
Reply
Thread Tools Display Modes
Old 2002-04-17, 09:12   #1
Lynne
Member
Vehicle(s): 71' Maverick Grabber
Question exhaust question...
Hello, I'm new to the board, glad to have found you all! My question is we are planning on chaning the exhaust on our 71' Grabber, we want to run 2 1/2 " off of the headers, into flow masters, and run it to dump out in front of the rear wheels. Does any one have a set up like this, and are there any problems with state inspections? We live in Massachusetts and were not sure if this would be a problem when it comes time to get an inspection sticker. Any info would be appreciated!!!
Thanks, Lynne
__________________
Lynne
Lynne is offline   Reply With Quote
Sponsored Links
Old 2002-04-17, 11:07   #2
'72 Comet GT
getting there
Vehicle(s): green 72 Comet GT
dumping in front of wheels
well, flowmasters are 50 state legal, at least according to them, if you already have headers noise definitely isn't a concern to you. Anyway, I actually just ran a very similar setup. The mufflers have a spot to hang, and its right at the rear wheels, actually the end of the muffler is close to the axle. doing dumps in front of the tires would be difficult, you would have to make a 180 from the muffler and then another 90 to exit. I have actually done this, with my buddy's muffler shop, but clearance was a problem. I'd hate to have to pay somebody to do it, just for cost reasons. Hope this helps!
'72 Comet GT is offline   Reply With Quote
Old 2002-04-17, 21:59   #3
Lynne
Member
Thanks for the info!!! I have a question for you, why did you put the mufflers in the stock position, couldn't you have put them right off the headers? Thats what we were thinking...
__________________
Lynne
Old 2002-04-17, 22:51   #4
Corbin Johnson
Senior Member
Corbin Johnson's Avatar
Vehicle(s): 73 LDO, 72 Sprint, 72 Sprint, 70 Grabber. NORCAL MCCI STATE REP.
Images: 6
Well...
The stock position is actually on the passengers side next to the gas tank. The "spot" '72 Comet GT is refering to is a place right in front of the rear axel where the mufflers fit nicely into because of the elevated floorpan underneath the rear seat. Putting mufflers right off the headers would pose some problems in the clearance department. They would be extreamly low to the ground, and scrape on every pot hole or bump in the road. If clearance is not a problem, it might work, but it would be sort of ugly in my opinion. You could see everything hanging down underneath when looking at the car from the outside. Just my 2 bits....
-Corbin
__________________
70 Grabber - 351W/C4. Grabber Green, Black Stripes, Green/White Houndstooth Top.
72 Sprint - Factory 302/C4, PS.
72 Sprint - Factory 302/C4, PS, AC
73 LDO - Factory 302/C4, AC, PS. Converted to small bumper, grabber look-a-like. Tan LDO Bucket interior, British Racing Green.
Corbin Johnson is offline   Reply With Quote
Old 2002-04-17, 22:59   #5
'72 Comet GT
getting there
Clearance
the main problem is clearance. from the headers the mufflers would sit under the floorpans, which just won't work. you can look for yourself, but you'd hit every speedbump in town.
Old 2002-04-18, 09:20   #6
Lynne
Member
exhaust question
Thanks 72' Comet GT and Corbin, I see what your saying! Sounds like to do this I'd have a mess of exhaust pipe going every where uner the car, or I'd be scraping the ground all the time. And your right, I don't want to see everything hanging down under the car either! Well I guess it's back to the drawing board for now.... Thanks again for your help! I'll let you know what we end up doing! Lynne
__________________
Lynne
Old 2002-04-18, 10:11   #7
Earl Branham
Certified Old Fart
Earl Branham's Avatar
Vehicle(s): '69.5 Maverick 302, T-5, Grabber Green
Images: 7
Lynn; I think it is best if you run them over the rear axle and out the rear, under the valence panel. It looks clean, and the mufflers fit just ahead of the axle, and out of the way. I am running turbo mufflers, crossover and chrome tips, and Flow Tech headers. It sounds good, and has good power. Give it a thought.
Earl
__________________
Earl Branham
Temple, GA
US Navy (Retired)
Earl Branham is offline   Reply With Quote
Old 2002-04-18, 10:31   #8
'72 Comet GT
getting there
Pictures
Tell you what, when I can get my car on a lift, I'll take pictures of how mine is run. Right now its squared off 180's. When I can buy mandrel-bent 180's I'll cut out and re-weld the new pieces. They're $20 apiece though!
Old 2002-04-18, 16:20   #9
K. Brock
Member
Vehicle(s): 1977 Mav, 2dr, p/s, p/b, 302 w/tremec 3550
jcwhitney.com has 45, 90 & 180 degree bends in 2.25 & 2.50 diameter tubing and they're reasonably priced. Call around....... you're likely to find a muffler shop that will build you what you want at a price you can afford. Just takes a little planning.
__________________
Kevin Brock
San Antonio, TX
K. Brock is offline   Reply With Quote
Old 2002-04-20, 12:25   #10
Threemav
Member
Vehicle(s): 69 mav pieced together from 2 73 mavs and a 73 grabber
I have 2x cherry bombs comming off the exaust manafolds and im having just that problem, there is no clearence and i hit every pothole in town, and every bump in the road, not to mention it looks like crap.
Threemav is offline   Reply With Quote
Reply
Interested in this thread?
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
My very own exhaust question 351wmav2 Technical 4 2007-01-29 16:04
Exhaust pipe routing question...again Gene Fiore Technical 8 2007-01-29 12:40
exhaust question DanielRoush Technical 6 2006-07-22 16:08
302 '74 Mav Exhaust Question... Doward Technical 5 2003-11-25 07:32
Exhaust question RudyD General Maverick/Comet 1 2002-03-29 14:22
Powered by: vBulletin
