Mobile Tags Register Gallery
Go Back   Ford Maverick / Mercury Comet Forums > Maverick/Comet Forums > Technical
Notices
Reply
Thread Tools Display Modes
Old 2006-12-06, 16:15   #1
scooper77515
Accepting Hand-me-downs
scooper77515's Avatar
Vehicle(s): 74 Mav 5.0 +.040 & C4
Images: 19
Adjusting the steering gear screw
Does anyone know the "correct" way to adjust the screw in the top of the steering gear box?
Mine is manual, in case it makes a difference.
Are there specific directions, such as "straighten the wheel, torque to X, then back of Y turns, and lock down"?
__________________
5.0 +.040 , roller .537/.574 224/232, 1.72 roller rockers, GT40, Holley 750 Street HP on Torker 289, 3.80 w/spool, CalTracs, dual Super44 Flows, R&C MII power rack suspension (no shock towers!), Vintage-Venom rear disks, lots of noise and everchanging custom calico paint
If you don't like it, I don't care
scooper77515 is offline   Reply With Quote
Sponsored Links
Old 2006-12-06, 17:19   #2
Jamie Miles
the road warrior
Jamie Miles's Avatar
Vehicle(s): 13 Mavericks
Images: 362
Quote:
Originally Posted by Earl Branham
if you have play in the wheel, loosen the 5/8" nut, and using a big screwdriver, screw the adjustment down, and move the wheel back and forth. This will take the slack out. Adjust the screw down until there is no play in the gear. Be sure to fill up the gear with grease, and it should be ok. Hope this helps.
May try giving Earl a PM if you need any help. From what I've heard, the wheels do need to be exactly straight.
__________________
facebook
1972 Maverick - daily driven 215,000+ miles since 2005. 433,000+ miles total on the car. Now with a 1980 200 I6/SROD 4 speed.. 2.79 rear gear, Rochester BC carb, single out header, MSD ignition, Taurus fan, 3G alternator. 31 mpg hwy. @ 70 mph / 25 city.
Jamie Miles is offline   Reply With Quote
Old 2006-12-06, 17:25   #3
ratio411
Member
ratio411's Avatar
Vehicle(s): 1972 Sprint and 1975 Maverick
Images: 16
The boxes are technically non-adjustable.
The "adjuster" is preset from the factory and not supposed to be used.
That is not to say you can't, however you should only move it very little.
For details, someone wrote up a thread about it a year or so ago.
I might be wrong, but I think it was dmhines.
The adjuster forces the gears together, so remember, very little adjustment is available before you cause things to bind up and ruin the box.
Good luck
Dave
__________________
A redneck's last words:
"Hey ya'll, watch this!"
ratio411 is offline   Reply With Quote
Old 2006-12-06, 18:32   #4
T.L.
Banned
T.L.'s Avatar
Vehicle(s): '73 Maverick 2-door, V-8
Images: 10
I disagree. The adjuster is there so that it can be adjusted, to take up the slack as the gears wear. Obviously there is only so much "adjustment" attainable before the box needs to be replaced.
Scoop;
The correct method is to loosen the nut, and tighten the screw with a flat-tip screwdriver. Just turn it clockwise until it stops. Do not put torque on it, or you will cause binding of the gears. Turn the screw until it stops, then retighten the nut. You're done. It's easy, takes less than 5 minutes, and it makes no difference if it's manual or power steering...
T.L. is offline   Reply With Quote
Old 2006-12-06, 19:08   #5
Fordmaster169
Member
Fordmaster169's Avatar
Vehicle(s): 1972 Maverick Grabber Pro Street Project, 1969 1/2 Mav 2dr, 1972 F-100 stepside 4X4, 2005 F-150 4X4, 2002 F150 FX4
Images: 1
Quote:
Ratio411 is correct. The adjuster is there for factory adjustment and when you do a rebuild. The reason I say this is that the most wear on the gears is at center with the wheels straight. As you go either way on the gear it will have less and less wear on it. So on a worn gear box if you adjust the slack out of the box at the center position it will get tighter and tighter as you turn the wheel and sometimes lock up. When you get a reman gear box from the parts store it has a red tag on it that says to please resist the urge to adjust the lash on the box. Hmmmm I wonder why that is.
So a solution to the problem would be to turn the wheels all the way in one direction and adjust it the way that T.L. has stated so you will not run into any binding problems.
__________________
A pic of the new engine for the 72 Grabber
"Only Wimps Wear Bow Ties"
Maverick Mafia Member #22
Fordmaster169 is offline   Reply With Quote
Old 2006-12-06, 19:22   #6
71gold
Frank Cooper
71gold's Avatar
Vehicle(s): '73 Grabber
Images: 45
Quote:
i disagree...the tight spot is in the center, that way it dosen't walk either way when going down the road..next!!!
...frank...
71gold is offline   Reply With Quote
Old 2006-12-06, 20:08   #7
Rick Book
Member
Rick Book's Avatar
Vehicle(s): Yamaha
Images: 34
10-14 inch lbs
source: http://autorepair.about.com/library/a/1f/bl869f.htm
I did this to my 1994 F-150 to try to get the slack out to the steering. Re-torquing the screw seemed to help ... a little bit. And, yes, the resistance to turning the steering increased also (by a small amount - I didn't have an inch/Lb torque wrench nor the patience of Scooper else I could quantify it. ).
Rick Book is offline   Reply With Quote
Old 2006-12-06, 20:48   #8
PaulS
Member extrordiare
Vehicle(s): 1966 Mustang, 1972, 73, 73 and 73 Mavericks
Yes, according to the manufacturer, the preload is adjustable.
The problem arises when the wear is too great for even application of the tension. The center of the worm gear is the tightest when it is new. It is also where most of the wear takes place. Once there is wear on the worm, it spreads to the follower and since it affects the center more than the extremes if you try to set the adjustment to take out the slack you have more wear in the center so when you adjust it there it is too tight on the extremes (the wear is less). In the books you will find the procedure to adjust the tension.
__________________
Paul
1 each 72 2dr., 73 2dr., 73 4dr., 66 Mustang Coupe.
PaulS is offline   Reply With Quote
Old 2006-12-07, 04:16   #9
Fordmaster169
Member
Images: 1
Thanks PaulS, I guess neither one of us has any idea what we are talking about. And yes, I learned the hard way about this very subject. The funny thing about experiance is you dont get any untill just after you need it.
And Frank, what keeps the car from walking down the road is not the preload on the worm and sector, it is an adjustment called CASTER.
__________________
Old 2006-12-07, 06:15   #10
scooper77515
Images: 19
Thanks guys. The reason I am even messing with it is because I have "rebuilt" it. Not really, but I took all the grease out, cleaned it, inspected it, put in a grease zerk, and reassembled it. I took that screw all the way out while doing this, and now need to put it back where it belongs. I left it a little loose just in case, figuring it would swim a little, but at least not damage anything, until I figured out what the correct torque was.
__________________
Reply
Interested in this thread?
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Steering gear mod... Earl Branham Technical 15 2012-11-13 11:52
Steering gear for manual steering Sixbanger Maverick/Comet Cars/Parts For Sale 5 2007-04-02 15:10
Steering gear for manual steering Sixbanger Maverick/Comet Cars/Parts For Sale 0 2006-11-10 19:23
Manual vs Power Steering Gear Boxes Acornridgeman Technical 19 2005-09-10 04:05
Bad steering gear box mike75mav Parts Interchange 3 2004-05-23 21:45
Powered by: vBulletin
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
