Super 44 sound clips
Discussion in 'Technical' started by scooper77515, Jun 19, 2007.
  1. scooper77515
    Please check out the sound clips at the bottom and tell me if they work. When I click on them Quicktime wants to run them and I hear nothing, but they are mp3 and should download and run in Windows Media Player.
    http://home.cmaaccess.com/~scodon/jpgs/44insidemp3.mp3
    http://home.cmaaccess.com/~scodon/jpgs/44outsidemp3.mp3
    Edit-- I had to reset my internet settings to open with Media Player, Quicktime had set itself as default, and would not let it play. So, feel free to download and open with Media Player, and that should work.
  2. 75Mav91Stang
    75Mav91Stang Member
    Essex Fells, NJ
    1970 and 1975 Ford Maverick
    Sounds sick man :) Where did you get those? I might want to pick up a pair..
    And what cam do you have?
    Edit: N/m saw the cam in your sig. :oops:
  3. scooper77515
    I got them at O'Reilly, but you can get them anywhere you buy Flowmasters...
    O'Reilly's was cheaper...$78 each. Summit and JEGS had about $85, but then you have to pay the handling fee of $10.
    Only took 24 hours to deliver.
    Cam is actually VERY road-friendly. It is the equivalent of an Edelbrock Performer Plus. Not even an RPM or anything. But I have 1.7 roller rockers on there, and plenty of lope. Idles at 450 if I want it to...:D
  4. dkstuck
    dkstuck Member
    Latrobe Pa (Pgh)
    72 Maverick in drag
    Sounds real good! Heard the fuel pump,,,where did you have the mic at? Outside (second) was the best hearing! I did like the play by play action you gave,,, just didn't hear much "snarling"
    I like the sound!
  5. scooper77515
    Outside was placed about 3 feet from the door on the ground. Then I reached out and brought it into the car with windows closed.
    Keep in mind, this is one of those old square cassette recorders, converted to mp3. It really does sound better in real life.
    I don't have the rear kickpanels installed so the fuel pump is REALLY loud right now (installed on inside of fender near tank).
  6. MNTony
    MNTony aka Godzirra
    Surprise, AZ
    Sounds good Scooper! The fuel pump would drive me nuts though! LOL I used to run dual holley blue's on my Mustang and the only way it was bareable was with open headers!
  7. NAFORD302
    NAFORD302 Member
    SILEX MO
    77 FACTORY V8 AC CAR
    Sounds Good WHAT WAS THE PART #
  8. NAFORD302
    NAFORD302 Member
    SILEX MO
    Where Are The Mufflers At Neer The Headers Or Towards The Rear Of The Car
  9. Pasc
    Quebec, Qc
    76 Stallion
    Sounds great!! (y)
  10. mcknight77
    mcknight77 Member
    Boise, ID
    74 Mav drag car, 1970 Maverick, 1971 Bronco, 66 Nova, 67 Ranchero
    I have the same cam in my Comet. Next step is to upgrade the heads. What headers are you running with the Ps?
  11. Jamie Miles
    Alto, GA
    I've had a few
    "I can still hear the fuel pump more then the mufflers..."
    Yea, so can we. :D
    Sounds awesome though! I've been trying to figgure out what mufflers to put on the Fiat to replace the crappy glass packs. Think I know now. (y)
  12. scooper77515
    Headers are regular Hooker 6901s. They hook right up to the P heads, but I made a spacer out of a spare header flange to help clear the spark plugs.
    Currently, the mufflers are stuck right onto the header collector reducer. Not welded or anything, just stuck on and hanging by their own weight.
    I will have it all hung and installed in week or so. It will sound a little different with 24" or so of straight pipe between the headers and the muffler, but I doubt it will change too much.
    Part # 942546...2-1/2" in and out, offset inlet, centered outlet. Flowmaster Super 44. They are probably the same as the Super 40s except only 4" thick rather than the 5" super 40s.
  13. fan2488
    fan2488 Member
    spring,TX
    1969.5 maverick, 1972 grabber
    i really like it scott
  14. Derek 5oComet
    Derek 5oComet Tire burner
    Welland,Ontario,Canada
    Scott the sound will change alot once you get some pipe in there.I did the same except welded the mufflers onto the reucers to get the car to the exhaust shop.Mine sounded completely different one the pipes were on.You will have to give us some more sound clips once it's finished.
    Derek.
  15. Rick Book
    Rick Book Member
    Thailand
    Missing my old '70 Maverick
    :bananaman
    Sounds very nice, Scott. Nice choice.
